unable to complete setup on Organizr
brat456
D
dlavigne
Guest
Have you created an issue on that project's github page?
brat456
here is the console message i am getting while finishing the admin setup of organizr
Organizr Function: Connection Failed eval code (1) (145,15) HTTP502: BAD GATEWAY - The server, while acting as a gateway or proxy, received an invalid response from the upstream server it accessed in attempting to fulfil the request. (XHR)POST - http://192.168.0.15/api/?v1/wizard_config
gt2416
I just tried the instructions from the git. No changes just blindly pasted all the commands and it works fine. I could get past the setup page and login like normal..Maybe delete the jail and try again ?
brat456
tried many times on different jails, but no success. I got it installed on virtualbox freenas and it worked fine without any issue.
don't know why this is happening on main server.
brat456
issue is resolved. after setting up organizr i just restarted my server and then created admin account through wizard and voila it's working falwlessly.
thanks guys
gt2416
LOL "Have you tried turning it off and on again ? "
is that just local link?
It's a local link. You could make it open to the Internet using port forwarding, but I wouldn't recommend it--that's why I'm only discussing using DNS validation to get the cert. But further discussion would probably be best on that thread.
