System Specs :
Asus P8H77-I Intel H77
Inet G2030
16GB DDR3
1 x Seagate 6TB - ST6000VN0041
2 x Seagate 3TB - ST3000VN000/ST3000DM001
1 x HGST 12TB - Drive not fully recognised - HGST HUH721212ALE6004
Intel ExpI9301CTBLK Network card
Sandisk Cruzer orbit 8GB- Boot Drive
OS - FreeNAS 11.3-Stable [release]
Hard drives are setup as JBOD - apologies if I have missed any details
I've been using Freenas for a few years now but I've only ever had it setup as JBOD, I started with one of the 3TB seagate drives, added another 3TB down the line and eventually a seagate 6TB, I recently bought a HGST 12 TB drive - which I used in my windows machine for a brief time, before more recently swapping it out for a 4TB with plans to add the 12TB into freenas, However I have run into a spot of trouble with that - from what I can see if I go into the GUI, seletc the storage drop down menu and then disks - the 12TB drive is not listed, what I do see listed is :
ada0 - this is the 6TB
ada1 - this is a 3TB
ada2 -this is a 3TB
da0 - this is the OS pen drive
da1 - I dont fully know what this is but Freenas gives the following information
Disk Type:
UNKNOWN
Description:
N/A
Model:
ONETOUCH MobileBroadBand
Transfer Mode:
Auto
Rotation Rate (RPM):
N/A
HDD Standby:
ALWAYS ON
Adv. Power Management:
DISABLED
Acoustic Level:
DISABLED
Enable S.M.A.R.T.:
true
S.M.A.R.T. extra options:
N/A
If I select Pools and try to create a new pool - the only option I have to create a new pool is with da1 which shows as 0B in size, no sign of the 12TB drive
I did some looking around and was unable to find any solution, but I did come across some information that may be helpful - If I use the command "camcontrol devlist" I get
<ST6000VN0041-2EL11C SC61> at scbus0 target 0 lun 0 (pass0,ada0)
<ST3000VN000-1H4167 SC43> at scbus0 target 1 lun 0 (pass1,ada1)
<ST3000DM001-1ER166 CC43> at scbus1 target 0 lun 0 (pass2,ada2)
<HGST HUH721212ALE604 LEGNW3D0> at scbus1 target 1 lun 0 (pass3,ada3)
<SanDisk Cruzer Orbit 1.26> at scbus5 target 0 lun 0 (pass4,da0)
Also with "gpart list"
and "sysctl kern.disks" gives - da0 ada3 ada1 ada0
So from what I can see, on some level Freenas can see the drive, ada3, but unable to let me use it? I'm not exactly sure, hopefully it is a simple fix, hope I have given enough information if not please feel free to ask.
Inet G2030
16GB DDR3
ada2 -this is a 3TB
Disk Type:
UNKNOWN
Description:
N/A
Model:
Transfer Mode:
Auto
N/A
HDD Standby:
ALWAYS ON
DISABLED
Acoustic Level:
DISABLED
Enable S.M.A.R.T.:
true
N/A
gpart list
Geom name: ada0
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 11721045127
first: 40
entries: 128
scheme: GPT
Providers:
1. Name: ada0p1
Mediasize: 2147483648 (2.0G)
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r0w0e0
efimedia: HD(1,GPT,ec3a2ed4-d483-11e8-89a0-10bf487f5347,0x80,0x400000)
rawuuid: ec3a2ed4-d483-11e8-89a0-10bf487f5347
rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b
label: (null)
length: 2147483648
offset: 65536
type: freebsd-swap
index: 1
end: 4194431
start: 128
2. Name: ada0p2
Mediasize: 5999027556352 (5.5T)
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r1w1e2
efimedia: HD(2,GPT,ec4cf7a2-d483-11e8-89a0-10bf487f5347,0x400080,0x2ba60f408)
rawuuid: ec4cf7a2-d483-11e8-89a0-10bf487f5347
rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b
label: (null)
length: 5999027556352
offset: 2147549184
type: freebsd-zfs
index: 2
end: 11721045127
start: 4194432
Consumers:
1. Name: ada0
Mediasize: 6001175126016 (5.5T)
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r1w1e3
Geom name: ada1
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 5860533127
first: 40
entries: 128
scheme: GPT
Providers:
1. Name: ada1p1
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r1w1e1
efimedia: HD(1,GPT,ee685a51-d483-11e8-89a0-10bf487f5347,0x80,0x400000)
rawuuid: ee685a51-d483-11e8-89a0-10bf487f5347
label: (null)
length: 2147483648
offset: 65536
type: freebsd-swap
index: 1
end: 4194431
start: 128
2. Name: ada1p2
Mediasize: 2998445412352 (2.7T)
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r1w1e2
efimedia: HD(2,GPT,ee7434b7-d483-11e8-89a0-10bf487f5347,0x400080,0x15d10a308)
rawuuid: ee7434b7-d483-11e8-89a0-10bf487f5347
label: (null)
length: 2998445412352
offset: 2147549184
type: freebsd-zfs
index: 2
end: 5860533127
start: 4194432
Consumers:
1. Name: ada1
Mediasize: 3000592982016 (2.7T)
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r2w2e5
Geom name: ada2
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 5860533127
first: 40
entries: 128
scheme: GPT
Providers:
1. Name: ada2p1
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r1w1e1
efimedia: HD(1,GPT,ce45d53f-d483-11e8-89a0-10bf487f5347,0x80,0x400000)
rawuuid: ce45d53f-d483-11e8-89a0-10bf487f5347
label: (null)
length: 2147483648
offset: 65536
type: freebsd-swap
index: 1
end: 4194431
start: 128
2. Name: ada2p2
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r1w1e2
efimedia: HD(2,GPT,ce547eca-d483-11e8-89a0-10bf487f5347,0x400080,0x15d10a308)
rawuuid: ce547eca-d483-11e8-89a0-10bf487f5347
label: (null)
offset: 2147549184
type: freebsd-zfs
index: 2
end: 5860533127
start: 4194432
Consumers:
1. Name: ada2
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r2w2e5
Geom name: ada3
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 23437770711
first: 40
entries: 128
scheme: GPT
Providers:
1. Name: ada3p1
Mediasize: 12000138584064 (11T)
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r0w0e0
efimedia: HD(1,GPT,ac9f5f0c-72e9-11eb-827c-001b213a5b1c,0x28,0x574ffffb0)
rawuuid: ac9f5f0c-72e9-11eb-827c-001b213a5b1c
label: (null)
length: 12000138584064
offset: 20480
type: freebsd-zfs
index: 1
end: 23437770711
start: 40
Consumers:
1. Name: ada3
Mediasize: 12000138625024 (11T)
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r0w0e0
Geom name: da0
modified: false
state: OK
fwheads: 255
fwsectors: 63
last: 15633367
first: 40
entries: 128
scheme: GPT
Providers:
1. Name: da0p1
Mediasize: 524288 (512K)
Sectorsize: 512
Stripesize: 0
Stripeoffset: 20480
Mode: r0w0e0
efimedia: HD(1,GPT,25be72cf-d309-11e8-a975-10bf487f5347,0x28,0x400)
rawuuid: 25be72cf-d309-11e8-a975-10bf487f5347
rawtype: 83bd6b9d-7f41-11dc-be0b-001560b84f0f
label: (null)
length: 524288
offset: 20480
type: freebsd-boot
index: 1
end: 1063
start: 40
2. Name: da0p2
Mediasize: 8003739648 (7.5G)
Sectorsize: 512
Stripesize: 0
Stripeoffset: 544768
Mode: r1w1e1
efimedia: HD(2,GPT,25dbad4a-d309-11e8-a975-10bf487f5347,0x428,0xee87b0)
rawuuid: 25dbad4a-d309-11e8-a975-10bf487f5347
label: (null)
length: 8003739648
offset: 544768
type: freebsd-zfs
index: 2
end: 15633367
start: 1064
Geom name: ada0
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 11721045127
first: 40
entries: 128
scheme: GPT
Providers:
1. Name: ada0p1
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r0w0e0
label: (null)
length: 2147483648
offset: 65536
type: freebsd-swap
index: 1
end: 4194431
start: 128
2. Name: ada0p2
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r1w1e2
label: (null)
offset: 2147549184
type: freebsd-zfs
index: 2
end: 11721045127
start: 4194432
Consumers:
1. Name: ada0
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r1w1e3
Geom name: ada1
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 5860533127
first: 40
entries: 128
scheme: GPT
Providers:
1. Name: ada1p1
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r1w1e1
label: (null)
length: 2147483648
offset: 65536
type: freebsd-swap
index: 1
end: 4194431
start: 128
2. Name: ada1p2
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r1w1e2
label: (null)
offset: 2147549184
type: freebsd-zfs
index: 2
end: 5860533127
start: 4194432
Consumers:
1. Name: ada1
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r2w2e5
Geom name: ada2
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 5860533127
first: 40
entries: 128
scheme: GPT
Providers:
1. Name: ada2p1
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r1w1e1
label: (null)
length: 2147483648
offset: 65536
type: freebsd-swap
index: 1
end: 4194431
start: 128
2. Name: ada2p2
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r1w1e2
label: (null)
offset: 2147549184
type: freebsd-zfs
index: 2
end: 5860533127
start: 4194432
Consumers:
1. Name: ada2
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r2w2e5
Geom name: ada3
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 23437770711
first: 40
entries: 128
scheme: GPT
Providers:
1. Name: ada3p1
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r0w0e0
label: (null)
offset: 20480
type: freebsd-zfs
index: 1
end: 23437770711
start: 40
Consumers:
1. Name: ada3
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r0w0e0
Geom name: da0
modified: false
state: OK
fwheads: 255
fwsectors: 63
last: 15633367
first: 40
entries: 128
scheme: GPT
Providers:
1. Name: da0p1
Sectorsize: 512
Stripesize: 0
Stripeoffset: 20480
Mode: r0w0e0
label: (null)
length: 524288
offset: 20480
type: freebsd-boot
index: 1
end: 1063
start: 40
2. Name: da0p2
Sectorsize: 512
Stripesize: 0
Mode: r1w1e1
label: (null)
length: 8003739648
offset: 544768
type: freebsd-zfs
index: 2
end: 15633367
start: 1064
