Unable 2 Import After Rebuild
moron101
Long story short: My Truenas Scale (initially had 2 vdevs, ZFS_1) start complaining about bad drives in each of the vdevs. I tried replacing them but resilvering appeared to be stuck despite repeated reboot.
I know that there's a good chance my data got corrupted. But I've since rebuilt my server and at this stage simply trying to salvage whatever data I can by importing my previous drives into my newly built server (same name etc.)
This is what I see in my disk list, but I cannot import:
Again, I'm resigned to data corruption and simply want to salvage what I can by bringing my data back on line and copying it somewhere else. Advise? A million thx in advance.
Richard
Arwen
If you could supply the output of the following commands, in CODE tags, that would help;
zpool list zpool import
Next, their is no such thing as "2 vdevs, ZFS_1". It's not a nit-picky thing, as their IS something called ZFS file system version. Which is up to 5. Of course, you probably meant 2 vDevs of RAID-Z1.
In general, you will want to use the correct terminology to avoid confusion;
moron101
You're correct in my meaning. Apologies for the sloppy wording. Well, doesn't matter now: I've decided to lose all my data and start from scratch.
Best,
Richard
