Tunables inside TrueNAS Scale - Need to modify rc.conf for OpenVPN server access to local network
DaSnipe
Hi everyone,
I'm setting up OpenVPN on my TrueNAS scale box, works great to ping the TrueNAS box and access the webGUI. However my usage for OpenVPN would be to access the subnet that the router (using ISP one for now, don't have a dedicated box or pfsense) and other computers/devices.
There's a couple of great guides built for core (https://www.truenas.com/community/t...ocumentation-for-openvpn-on-truenas-12.92768/) and videos on Youtube (https://www.youtube.com/watch?v=YEkfW4aC9Rk&t=1226s), which are great but SCALE doesn't have a tunables section for rc.conf. I know I can modify sysctl but not rc.conf tunables to modify the firewall and gateway, since I'd need to modify the following options
Tunables:
firewall_enable
firewall_type
gateway_enable
natd_enable
natd_interface
natd_flags -dynamic -m
In order to route the traffic setup in the additonal parameters of the OpenVPN server:
Additional Parameters:
push "route 192.168.0.0 255.255.255.0"
push "redirect-gateway def1 bypass-dhcp"
push "dhcp-option DNS 8.8.8.8"
push "dhcp-option DNS 1.1.1.1"
Is there a way to do this in SCALE?
I know I can run a VM bridge that to my local network (with or without OpenVPN) but I'd love to use the built-in SCALE VPN server to access all my network.
aadje93
system settings -> advanced -> tunables
wahlstedtw
I have the same Issue as DaSnipe. There is no tunables option in TrueNAS Scale. Do we know if this will be added?
LarsR
i think the equivalent of tunables in scale is the sysctl menu point under system settings -> advanced
ruiloba
1) You need to create a directory to locate a file with the firewall rule, so that it is persistent between restarts
Open Console (I already have a directory for FW rules)
cd /mnt/sistema/firewall
Edit a file for the rule (format: ip saddr (VPN_address) oif "(LAN_interface)" snat to (LAN_NAS_IP_address))
vi nftables_nat
INSERT
#!/usr/sbin/nft -f
table ip nat {
        chain postrouting {
                type nat hook postrouting priority srcnat; policy accept;
                ip saddr 10.20.0.0/24 oif "eno1" snat to 192.168.1.4
we leave
:WQ!
edit permissions
chmod 755 nftables_nat
we're done with the console
exit
2) enable the kernel for ipv4 forward
go to the nas management website and open
System Settings -> Advanced -> sysctl
press
Add
Insert
Variable net.ipv4.ip_forward
Value 1
Description net.ipv4.ip_forward
Enabled Marked
press
SAVE
3) enable the firewall
go to
System Settings -> Advanced -> Init/Shutdown Scripts
press
Add
Insert
Description enable nftables
Type Command
Command systemctl enable nftables
When Post Init
Enabled Marked
Timeout 10
press
SAVE
4) activate the firewall
press
Add
Insert
Description start nftables
Type Command
Command systemctl start nftables
When Post Init
Enabled Marked
Timeout 10
press
SAVE
5) insert the NAT rules
press
Add
Insert
Description nftables nat rules
Type Command
Command nft -f /mnt/sistema/firewall/nftables_nat
When Post Init
Enabled Marked
Timeout 10
press
SAVE
you have to restart the nas for the changes to be effective
Testing the fw service by console
root@NAS[~]# systemctl status nftables
● nftables.service - nftables
Loaded: loaded (/lib/systemd/system/nftables.service; enabled; vendor pres>
Active: active (exited) since Mon 2022-04-11 00:15:36 CEST; 38min ago
Docs: man:nft(8)
http://wiki.nftables.org
Main PID: 653 (code=exited, status=0/SUCCESS)
Tasks: 0 (limit: 18401)
Memory: 0B
CGroup: /system.slice/nftables.service
Apr 11 00:15:36 NAS.local systemd[1]: Finished nftables.
Warning: journal has been rotated since unit was started, output may be incompl>
root@NAS[~]# nft -a list table ip nat
table ip nat { # handle 5
chain postrouting { # handle 1
ip saddr 10.20.0.0/24 oif "eno1" snat to 192.168.1.4 # handle 2
Enjoy!
Saverix98
vi nftables_nat
INSERT
#!/usr/sbin/nft -f
table ip nat {
        chain postrouting {
we leave
:WQ!
edit permissions
exit
press
Add
Insert
Value 1
Enabled Marked
press
SAVE
go to
press
Add
Insert
Type Command
When Post Init
Enabled Marked
Timeout 10
press
SAVE
press
Add
Insert
Type Command
When Post Init
Enabled Marked
Timeout 10
press
SAVE
press
Add
Insert
Type Command
When Post Init
Enabled Marked
Timeout 10
press
SAVE
Docs: man:nft(8)
Memory: 0B
Enjoy!
Hi, I tried to follow these steps but my OpenVPN is not working. I’m able to connect to my OpenVPN server but I can’t go on Internet and I can’t access my server services like Nextcloud. What’s wrong? Can you help me?
DaSnipe
Nice, more resources are great.
I currently use TrueCharts docker-compose along with WireGuard (WG-easy) since it’s a lot easier to manage users/generate config files
Vincent_D
Hello everyone. I also have a problem like this, I can connect to the TrueNas server and my apps such as qb torrent, transmission and emby with my phone outside my network. I also have the same public ip address on my phone as on my server.
But I dont have access to the internet. The parameters I am using is this:
push "route 192.168.1.0 255.255.255.0"
I also have set the OpenVPN server address and static route to 192.168.2.0
*EDIT - I just deleted the push "redirect-gateway def1 bypass-dhcp" and then I had access to my LAN and the internet, but with different public ip addresses on the server and on the phone.
rs_taylor
The line you removed means you are using you VPN clients existing gateway to access Internet, not the VPN Server and its Gateway.
When you had the Gateway redirected to the VPN Server then it was NOT routing you correctly.
I had same issue, could never get the VPN server to route traffic at all, but as i only needed access to the Shares and Apps on the TrueNAS Scale/VPN Server's single IP (all apps are on its ports not their own IP's) and didn't want to use the Remote locations Internet anyway (to fool netflix for example), so took out all routing (no static routes tunables/Init Variables etc). only have the certs to get OpenVPN connected and 3 lines in the Additional Parameters of the VPN Server Service config
push "route 192.168.31.0 255.255.255.0" - The network of the TRUENAS/Open VPN server
duplicate-cn - Without this each device i connected via VPN was given the same IP, no idea why, but this fixed that.
keepalive 10 60 - keeps the connection up when not used constantly.
works great for me.
