EnragedZeus05
- Sep 29, 2021
hello,
I have been lurking on the TrueNas Forum and on reddit for a few months now, mostly just reading up to prep myself to correct a massive wrong that i have frakensteined over the last 10-15 years. I currently have a server in a massive hardware raid 60 w/ 24 6tb disks and some SSDs in a r620XD im currently using. Yes, i know how bad it is but it sort of grew into this monster from only 2 2tb disks. i have a total of 110tb of data that i am storing.
I am finally ready to fix this and have "most" of the hardware but i have a few questions that i cannot locate on this forum, reddit, google, or i just cant understand it for some reason.
My case use is file storage only. Plex storage, pictures, personal cloud, etc. No VM's but i might get a few SSDs and try to make a pool out of those for games.
The hard drives i am aiming to get is HGST 6tb enterprise helium drives (used/ebay) which will be stored in a NetApp DS4486 (48 bay drive enclosure). I do have two of these enclosures that i will eventually put more 6tb drives in or possibly 8tb drives in down the road for growth.
I also have a NetApp DS2246 which holds 24 2.5 SSDs which i will be using to multiple pools to host my plex DB, stuff i need to either archive/unpack, and lastly stuff that i need speed for transferring over the network.
i have acquired a Dell R730XD barebones (only missing ram/CPU/storage cards).
So, as it sit i only need the CPUs, RAM, NIC, and the HBA's. I mostly need help hammering out which HBA's ill need to connect to the diskshelf and to the local drives in the R730XD, CPU, and 10gb NIC.
I have been eye balling the Intel XEON E5-2640 2.6Ghz 8 core cpu but i can also get a 4 core 3.0 Ghz cpu if that is the better route. I planned on getting 1 CPU 2/ 64gb of ram to start. also, would 2 CPU's be better/needed for performance?
The HBA's i am getting confused a lot. Do i need card with more ports? do i need a sas expander?
10gb NICs seem to be all over the place while some have issues and some dont. Was hoping to get feed back on the "best" card that works out of the box.
Thanks for any replies and advice to get me going in the right direction. i really need to do this right the first time because i am not looking forward to moving 110tb :/
