Trying to delete "ix-applications" dataset results in panic
fsociety3765
Hi all,
I'm trying to reset and delete ix-applications but whenever I do it's crashing Truenas. The system just halts and then reboots.
Tried from web GUI and CLI.
I have unset the pool in Applications. The app service is not configured. However, trying to rm -rf the data manually in the ix-applications dataset result in "device in use/busy" etc.
If I try to set the pool again for the app service it also crashes and reboots.
There are several snapshots relating to the dataset as well that I have tried to delete but that also just results in panic and reboot.
Not exactly sure what the issue is. I was on the latest release of Cobia when this issue started. I have updated to Dragonfish RC today in hope that maybe it was bug but still have the same issue on today's RC of Dragonfish.
Any ideas?
Thanks,
FS
chrisuthe
I moved my ix-applications storage to another pool, rebooted and successfully removed the old dataset on the old pool via UI with no issue just now, as another data point :)
William Grzybowski
Apart from some sort of hardware issue this should not be happening and should be treated as a bug.
Please create one in our Jira including the debug so we can take a deeper look.
