Trying to create a script to update inside all my jails.
Wolfeman0101
I was trying to create something I could run that would look for all my jails and run an update/upgrade in each one. This is what I have so far but it's not working. I've never done bash scripting.
#!/bin/bash
declare -a vars
eval "vars=(`/usr/local/bin/iocage list | awk '{ print $4 }' | sed '2d' | grep .`)"
for i in $vars; do
    /usr/local/bin/iocage exec "${vars[$I]}" "pkg update && pkg upgrade" | grep -q 'Your $var packages are up to date.'
done
You are pretty close as written. Heres what I have with a little more feedback.
#!/bin/bash
declare -a vars
eval "vars=(`/usr/local/bin/iocage list | awk '{ print $4 }' | sed '2d' | grep >
for ((I = 0; I < ${#vars[@]}; ++I )); do
echo -e "\e[1;31m Starting Update of "${vars[$I]}" \e[0m"
    /usr/local/bin/iocage exec "${vars[$I]}" "pkg update && pkg upgrade -y"
echo -e "\e[1;31m Update of "${vars[$I]}" Complete \e[0m"
done
I suspect the only thing holding up yours might have been the -y after pkg upgrade
Wolfeman0101
#!/bin/bash
declare -a vars
done
I'm getting this error.
bkwolfe@Packers:~ % sudo ./update
Password:
./update: line 3: unexpected EOF while looking for matching ``'
./update: line 9: syntax error: unexpected end of file
bkwolfe@Packers:~ %
Interesting and useful. A couple of questions though:
1. Is pkg update required? The reason I'm asking is this extract from pkg help update
It is best practice to ensure your package repository catalogues are up
to date before doing any package installation (via pkg-install(8)) or
upgrades (via pkg-upgrade(8)). However, explicitly running pkg update is
not normally necessary. By default invoking either of pkg install or pkg
upgrade will cause repository catalogues to be updated automatically,
unless disabled by setting REPO_AUTOUPDATE to false in pkg.conf(5).
2. If pkg update is recommended, are additional switches required? The reason for this question is that when I manually upgraded an 11.3 jail the other day, this was the output:
root@wp-blog:~ # pkg update -f
Updating FreeBSD repository catalogue...
[wp-blog] Fetching meta.conf: 100%    163 B   0.2kB/s    00:01
[wp-blog] Fetching packagesite.txz: 100%    6 MiB   3.0MB/s    00:02
Processing entries:   0%
Newer FreeBSD version for package libXdamage:
To ignore this error set IGNORE_OSVERSION=yes
- package: 1104001
- running kernel: 1103000
Ignore the mismatch and continue? [y/N]: y
Processing entries: 100%
FreeBSD repository update completed. 28812 packages processed.
All repositories are up to date.
Jailer
Not strong, but bad
2. If pkg update is recommended, are additional switches required? The reason for this question is that when I manually upgraded a 11.3 jail the other day, this was the output:
That's because FreeBSD 11.3 is no longer supported. The -y switch would have allowed the script to continue on and upgraded the packages based on the 11.4 ports tree and it's dependencies.
This is a good example of why I personally don't like automatic upgrade jail scripts. I want to know what's going on with my jail before the upgrade takes place in case the upgrade breaks something so I'm not poking around in the dark trying to figure out why it broke.
hertzsae
The '-y' switch does not work for pkg update with a version mismatch. I updated the jails to 11.4 (with freenas still at 11.3) to get past the prompt.
I didn't realize until now you were running 11, so yeah expect breakage. Mine quietly runs once a month and does it's thing complete and results come in an email. Ymmv. I'm up to date everywhere.
SweetAndLow
Sweet'NASty
Seems really complicated I just did this
for n in `iocage list -h -q | awk '{print $1}'`; do iocage update $n; sleep 1; iocage pkg $n upgrade -y; done
iocage restart ALL
hertzsae
iocage restart ALL
Love the simple solution. I ran into issues with restart when one of the applications didn't shut down properly which failed out the restart All command before the others reset. Borrowing your code, I switched to:
for n in `iocage list -h -q | awk '{print $1}'`; do iocage update $n; sleep 1; iocage pkg $n upgrade -y; iocage stop $n; sleep 1; iocage start $n; done
iocage list -l
I also take snapshots of all the jail configuration data before I run this.
I have to agree with you. The version mismatch I referred to broke SSMTP in a number of my jails. I've found the culprit and have resolved the issue, but had I run an automatic upgrade script, the source of the issue might have remained a mystery to me.
