SOLVED Help with a script to update jails
mow4cash
I have this script set up as a cron job running as root. plexpy works fine but that is because /usr/local/etc/rc.d/plexpy has nobody:wheel permissions. How can I make the others work with root:wheel permissions? Does my script look ok?
#!/bin/bash
for JAIL in Sonarr Radarr Jackett Plex Transmission Plexpy
do
  jexec $JAIL pkg upgrade -y
done
for SERVICE in sonarr radarr jackett plexmediaserver transmission plexpy
do
  jexec -u root $JAIL service $SERVICE restart
done
### Parameters ###
logfile="/tmp/jail_update.tmp"
email="myemail@gmail.com"
subject="Jails update for FreeNAS"
### Set email headers ###
	echo "To: ${email}"
	echo "Subject: ${subject}"
	echo "Content-Type: text/html"
	echo "MIME-Version: 1.0"
	echo -e "\\r\\n"
) > ${logfile}
### Set email body ###
	echo "<pre style=\"font-size:14px\">"
	echo "##### Jails Updated #####"
	echo "$JAIL"
) >> ${logfile}
### Send report ###
sendmail -t < ${logfile}
rm ${logfile}
No. Your second for loop doesn't run until your first is complete, so it only runs with the value of $JAIL set to Plexpy. I'm 99% sure that's your problem. And since your script is running as root anyway, there's no need for the -u root on the second jexec command.
mow4cash
Yep that did it. I did done done. Not very eloquent but it works for now.
