Trying to browse into iocage in Shell but get permission denied at every folder level
rebo00
OS: FreeNAS-11.3-U2.1
I open Shell > logs in as root > type /mnt > enter > zsh: permission denied: /mnt
I understand that root has been removed from accessing anything via shell and that /mnt isn't accessible anyway, ok.
I open Shell > login > admin and password > type /mnt/***STORAGE POOL NAME***/iocage/jails/jail name/ > /mnt/***STORAGE POOL NAME***/iocage/jails/jail name/: Permission denied
I get this with any folder in the entire structure.
I need to get into the Databases folder to run a command and backup some files.
Any ideas?
Regards,
Andy
Redcoat
How about open shell as root, type cd /mnt/***STORAGE POOL NAME***/iocage/jails/jail name<CR> ?
Samuel Tai
Have you tried the Shell button for the jail itself?
SweetAndLow
Sweet'NASty
Any ideas?
Regards,
Andy
Your just using the wrong commands. Need to use cd.
rebo00
This, don't know how I didn't find anything on that.
So what does just typing the directory in without cd actually try to do?
Thanks for the replies, appeciated.
Regards,
Andy
SweetAndLow
Sweet'NASty
Regards,
Andy
It tries to execute it like a program. First thing in the cmd is almost always a program of some kind.
Redcoat
Once you have arrived at your destination directory using "cd" (change directory), then "ls" to list contents. I suggest that you look at the FreeBSD man pages for the commands for clarification on them.
Top Bottom
