trusted_domains nextcloud
pepefl3
I just installed nextcloud in my TrueNAS-SCALE-22.02.0. how can I edit the config.php file in nextcloud or where is the config.php located so I can edit it. Thank you in advance.
James Doyle
I fixed it a different way.
1. SSH into your FreeNAS box and become root.
2. invade the root of the jail: # cd /mnt/zones/iocage/jails/nextcloud/root/
3. find config.php: # find . -name "config.php"
4. edit config.php: # vi usr/local/www/nextcloud/config/config.php
5. Find the trusted_domains block and add the IP address of the Jail: (in my case, since the URL offered by "Manage" in the FreeNAS Plugins UI was offered as https://192.168.2.207/login, use that IP
'trusted_domains' =>
array (
0 => 'localhost',
1 => '192.168.2.2',
2 => '192.168.2.207'
6. In the Plugins UI panel, Stop and Start the Jail
7. Hit that "Manage" Button - a new browser window will launch
8. Get the password for user 'ncadmin' from the "Post Install Notes" Icon offered in the Plugins UI panel.
canosgmk
This doesn't work for "Scale" Scale dosn't have "JAIL" options.
if you have CORE, just have to use the JAIL option in the GUI.
