PunyEarthling76
- Feb 16, 2024
If like me you switched from core to scale and forgot that settings edited in transmission webgui are not persistent. Then the following list of environment variables may be of use and you can add them using the edit option if you have the transmission deployed and + additional environment variables option. Link was found in one of the readme.* in the deployment. I did notice it's not a complete list but given the format having a guess and looking at the settings.json where your app is deployed seems to map with uppercase and -/_ changes.
I saw there was some option to install a truecharts app catalogue and that transmission version has a lot of these settings in scale gui. I didn't like that as it's too busy for me and I only need tweak upload/download speeds. Also I know what I changed for default as it's the only additions.
github.com
This might all be documented somewhere but I couldn't find it.
containers/apps/transmission at main · onedr0p/containers
My collection of container images. Contribute to onedr0p/containers development by creating an account on GitHub.
