Truenas to Freenas replication task
Gob
Hi
I have an urgent requirement to replication some dataset snapshots from a TrueNas to a FreeNas before I remove the FreeNas to a location several hundred miles away. So posting here in addition to TrueNas support in the hope of a quick resolution.
I set up my first rep task and it seemed to work perfetly. Created the remote dataset and populated it fine. But I then get an error saying "remote destination must be set readonly". Is it asking me to change the permissions on the remote dataset? Does that matter?
But more worryingly, when I added more rep tasks where the source dataset has a space in the name the replication fails completely with "remote system not responding".
Here is a shot of my tasks which led me to that conclusion:
Could this just be an issue between True & Free NAS? Both are on the latest versions.
Is it a known issue with the spaces in the dataset name?
Any help would be really appreciated.
Thanks.
Gob
Almost Dru,
The wonderful guys on TrueNas support have replicated the issue and are looking at a fix.
Gob
@chartley21
IX support fixed the issue and I believe have released a patch for inclusion in both TrueNAS and FreeNAS updates in the coming weeks.
Hope that sorts it for you!
