Truenas Scale Uptime 1 hour faster
Rkinsey
Hi All,
So sorry if this has already been asked, I did find one post but I'm not as clued up on IX systems and coding. (Mainly used command prompt in windows) only just really started to learn things like linux etc.
So My issues is that my Scales says it uptime is 1 hour faster than the actual time in my time zone. I have check my MB and that is saying the correct time and I have changed my time in the local settings.
I just don't know how to fix the uptime and I feel it is messing with my Netdata as it cant pull anything from the Scale and states there is a timing error. Any help would be great.
Newbie here
Redcoat
You need to set your Scale box time to UTC (which is one hour behind BST)
HoneyBadger
actually does care
Administrator
Notably, you need to set the hardware (BIOS or RTC) time to UTC, and then set the time zone in the TrueNAS WebUI.
Redcoat
That is a much more precise way to say what I was trying to get across...
