TrueNas Scale Unable to stop Kubernete on on TrueNAS-SCALE-22.12-RC.1
browntiger
I seems to gained a feature on TrueNAS-SCALE-22.12-RC.1
Unable to stop one of my Kubernetes [Calibre] (infinite loop)... Get's stuck on "fetching data...". This worked fine in the prior BETA. Not sure what happened in between. Calibre is setup with PVC and 999Gi and Hostpath (none of that "Simple").
I did: k3s kubectl delete pod XXXXX -n xxx
(deleted),
But it immediately redeployed. With the same result. k3s work flawlessly, so this is something about UI.
Just letting you know.
browntiger
Here is the log if it helps (for newly re-deployed pod), and full pod namespace yaml.
And two services
NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE
calibre-webserver LoadBalancer 172.17.134.40 192.168.1.7 8081:35604/TCP 24h
calibre LoadBalancer 172.17.41.237 192.168.1.7 8084:20880/TCP 24h
  • calibre_calibre-78ff5fd8c8-nw2ws_calibre.zip
  • PodYaml.zip
morganL
Captain Morgan
Administrator
And two services
Did this occur immediately after the update to RC1?
Any other changes?
browntiger
It looks like after 6 hours after the upgrade I was able to finally stop my "calibre" container. ("IT IS RESOLVED")
What is odd UI "stop" would work for all other containers, but NOT calibre. Not sure if there is PHREAD or process LIMIT.... /???
