electricspaghetti
- Feb 23, 2022
I have TrueNAS-SCALE-22.02.0 installed on a HP EliteDesk 800 G1 with an i5-4690 CPU @ 3.50GHz and 8GB ram.
It has been running for about a month while I familiarize myself with the setup. I am a noob.
Internally it has one 256gb SSD drive
Externally it has
1 x 3tb USB3.0 WD drive
1 x 6tb USB3.0 drive
The following pools were created, one for each drive
Internal 256GB drive - boot-pool
External 3TB drive - Data3tb
External 6TB drive - Video6tb
At some point TrueNAS changed the status of the external 3TB Pool to offline.
The alert reads :
The drive still shows as connected under Storage>Disks but the Pool reads as N/A.
The SMART test shows a result of short offline as SUCCESS
I'm lost.
Is there a means by which I can online this drive/pool or do I need to remove it entirely and plug in a different drive?
Thanks
Externally it has
The alert reads :
Pool Data3tb is offline, not running scrub.
I'm lost.
Thanks
