Hello There,
we have many installations of TrueNAS Core and TrueNAS Scale that we monitor using Zabbix via SNMP.
With TrueNAS Core we can retrieve info about datasets:
we just use this Template and it works out of the box with TrueNAS Core
www.zabbix.com
With TrueNAS Scale, however, we are not able to retrieve dataset information.
In TrueNAS Scale, looking at the SNMP specification using snmpwalk, shows there are no infos about datasets, just zpools.
Any idea?
Thank you
TrueNAS monitoring and integration with Zabbix
Any idea?
Thank you
