Help with SNMP monitoring of TrueNAS Scale in Zabbix; OID for ZPool Health not right?
surfrock66
I'm using a fully updated Zabbix environment and am using the built-in TrueNAS SNMP monitoring template to watch my TrueNAS Scale environment. I think it was written for TrueNAS Core, but it works just about perfectly for TrueNAS Scale. My TrueNAS environment is 22.12.1.
Discovery is fine, however I get 2 "Problems" with my 2 pools, my "boot-pool" and "sr66-nas-v01" in regard to the following sensor: "TrueNAS: Pool [sr66-nas-v01]: Status is not online". This is from the following discovery trigger:
last(/HOSTNAME.SUBDOMAIN.DOMAIN.com/truenas.zpool.health[sr66-nas-v01]) <> 0
That item is built with the following SNMP OID in the item prototypes:
.1.3.6.1.4.1.50536.1.1.1.1.7.{#SNMPINDEX}
{#SNMPINDEX} is getting discovered as "1" for boot-pool and "2" for sr66-nas-v01.
Now, the MIB for this is defined here: https://mibs.observium.org/mib/FREENAS-MIB/#zpoolHealth
Unfortunately, there's a disconnect. The values expected would be this:
online(0),
degraded(1),
faulted(2),
offline(3),
unavail(4),
removed(5)
However, the value I am getting from that OID is some giant integer:
I am thinking the pool index in regards to the OID is wrong, so it's pulling the wrong value. I don't see documentation for the OID's which should be presented by TrueNAS, but if I know what the OID should be for individual discovered zpools, I'm happy to submit a pull request to fix the template.
morganL
Captain Morgan
Administrator
Perhaps update to SCALE 22.12.2 and see if issue persists.
surfrock66
Wow, that's released today. I usually don't update on day 1, but thx for letting me know to check. I doubt it's that; I would think an OID change would be a bigger change than a point rev. My guess is this is something different between core/scale.
serhii.prk
I have the same problem. Already updated to latest version but problem still exist. It's had returned not valid data
root@zabbix:~# snmpwalk -v2c -c public <host_address> .1.3.6.1.4.1.50536.1.1.1.1.7
iso.3.6.1.4.1.50536.1.1.1.1.7.1 = Counter64: 43461197824
iso.3.6.1.4.1.50536.1.1.1.1.7.2 = Counter64: 164410417152
serhii.prk
i had find decision.
root@zabbix:~# snmpwalk -v2c -c public <host_addres> .1.3.6.1.4.1.50536.1.1.1.1.3
iso.3.6.1.4.1.50536.1.1.1.1.3.1 = STRING: "ONLINE"
iso.3.6.1.4.1.50536.1.1.1.1.3.2 = STRING: "ONLINE"
so need just fix zabbix template
dauntless101
Sorry, what did you change in the template to fix this? Thanks
I updated to the lastet version of the template from the repo and looks like the problem still exists today.
salvadorgzz
Not @serhii.prk, but I was able to get use his notes and figure out how to fix the template. I'm not sure if this is the proper fix, but it works locally. Hopefully this helps who ever next runs into this problem.
1. Open the template. (Go to data collection / templates / search for truenas).
2. Find the ZFS pools discovery rule. (In the discovery rules section)
3. In item prototypes, edit the "TrueNAS: Pool [{#POOLNAME}]: Health" prototype. I changed the SNMP OID to ".1.3.6.1.4.1.50536.1.1.1.1.3.{#SNMPINDEX}", and the Type of information to Text. Then save/update.
4. Edit trigger prototypes. (Since the type of info changed to text, the old trigger expression needs updating.) Look up the trigger prototype called "TrueNAS: Pool [{#POOLNAME}]: Status is not online". Change the expression to:
last(/TrueNAS by SNMP/truenas.zpool.health[{#POOLNAME}]) <> "ONLINE"
I don't know if this was needed or not, but to quickly see the updates applied, I went to the host and in the templates section unlinked and cleared the template and added it back again.
