Hi All,
I had a power failure and had to restart my TrueNAS server. When trying to start the service, i am getting the following error:
Not sure what would have caused this to happen,
Any Ideas?
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 196, in call_method
result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1335, in _call
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1318, in nf
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1186, in nf
res = await f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/service.py", line 191, in start
raise CallError(await service_object.failure_logs() or 'Service not running after start')
middlewared.service_exception.CallError: [EFAULT] May 27 11:01:59 systemd[1]: Dependency failed for Samba SMB Daemon.
May 27 11:01:59 systemd[1]: smbd.service: Job smbd.service/start failed with result 'dependency'.
May 27 11:06:15 systemd[1]: Dependency failed for Samba SMB Daemon.
May 27 11:06:15 systemd[1]: smbd.service: Job smbd.service/start failed with result 'dependency'.
May 27 11:09:59 systemd[1]: Dependency failed for Samba SMB Daemon.
May 27 11:09:59 systemd[1]: smbd.service: Job smbd.service/start failed with result 'dependency'.
May 27 11:14:19 systemd[1]: Dependency failed for Samba SMB Daemon.
May 27 11:14:19 systemd[1]: smbd.service: Job smbd.service/start failed with result 'dependency'.
May 27 11:19:20 systemd[1]: Dependency failed for Samba SMB Daemon.
May 27 11:19:20 systemd[1]: smbd.service: Job smbd.service/start failed with result 'dependency'.
May 27 11:20:15 systemd[1]: Dependency failed for Samba SMB Daemon.
May 27 11:20:15 systemd[1]: smbd.service: Job smbd.service/start failed with result 'dependency'.
May 27 11:25:36 systemd[1]: Dependency failed for Samba SMB Daemon.
May 27 11:25:36 systemd[1]: smbd.service: Job smbd.service/start failed with result 'dependency'.
May 27 11:27:21 systemd[1]: Dependency failed for Samba SMB Daemon.
May 27 11:27:21 systemd[1]: smbd.service: Job smbd.service/start failed with result 'dependency'.
May 27 11:33:23 systemd[1]: Dependency failed for Samba SMB Daemon.
May 27 11:33:23 systemd[1]: smbd.service: Job smbd.service/start failed with result 'dependency'.Not sure what would have caused this to happen,
Any Ideas?
