Currently running TrueNAS-SCALE-22.02.2 and get the below log entries when trying to turn the SMB service on.
All that has been done to it is:
- AD Join
- 1 Pool created
- 2 Datasets
Thoughts?
tail -f /var/log/syslog
Jul 4 07:21:13 everest-tns01 winbindd[3044738]: [2022/07/04 07:21:13.325889, 0] ../../source3/lib/dumpcore.c:256(dump_core_setup)
Jul 4 07:21:13 everest-tns01 systemd[1]: winbind.service: Main process exited, code=exited, status=1/FAILURE
Jul 4 07:21:13 everest-tns01 winbindd[3044738]: Unable to setup corepath for winbindd: No such file or directory
Jul 4 07:21:13 everest-tns01 winbindd[3044738]: [2022/07/04 07:21:13.325957, 0] ../../lib/util/util.c:212(directory_create_or_exist)
Jul 4 07:21:13 everest-tns01 systemd[1]: winbind.service: Failed with result 'exit-code'.
Jul 4 07:21:13 everest-tns01 winbindd[3044738]: directory_create_or_exist: mkdir failed on directory /var/db/system/samba4/private/msg.sock: No such file or directory
Jul 4 07:21:13 everest-tns01 systemd[1]: Failed to start Samba Winbind Daemon.
Jul 4 07:21:13 everest-tns01 systemd[1]: Dependency failed for Samba SMB Daemon.
Jul 4 07:21:13 everest-tns01 systemd[1]: smbd.service: Job smbd.service/start failed with result 'dependency'.
Jul 4 07:21:13 everest-tns01 systemd[1]: Cannot find unit for notify message of PID 3044736, ignoring.
Jul 4 07:21:28 everest-tns01 systemd[1]: Starting Samba Winbind Daemon...
Jul 4 07:21:28 everest-tns01 winbindd[3047096]: [2022/07/04 07:21:28, 0] ../../lib/util/debug.c:1100(reopen_one_log)
Jul 4 07:21:28 everest-tns01 winbindd[3047096]: reopen_one_log: Unable to open new log file '/var/log/samba4/log.winbindd': No such file or directory
Jul 4 07:21:28 everest-tns01 winbindd[3047096]: [2022/07/04 07:21:28, 0] ../../lib/util/util.c:212(directory_create_or_exist)
Jul 4 07:21:28 everest-tns01 winbindd[3047096]: directory_create_or_exist: mkdir failed on directory /var/log/samba4/cores: No such file or directory
Jul 4 07:21:28 everest-tns01 winbindd[3047096]: [2022/07/04 07:21:28, 0] ../../source3/lib/dumpcore.c:59(get_default_corepath)
Jul 4 07:21:28 everest-tns01 winbindd[3047096]: Failed to create /var/log/samba4/cores for user 0 with mode 0700
Jul 4 07:21:28 everest-tns01 winbindd[3047096]: [2022/07/04 07:21:28, 0] ../../source3/lib/dumpcore.c:256(dump_core_setup)
Jul 4 07:21:28 everest-tns01 winbindd[3047096]: Unable to setup corepath for winbindd: No such file or directory
Jul 4 07:21:28 everest-tns01 winbindd[3047096]: [2022/07/04 07:21:28.879748, 0] ../../lib/util/debug.c:1100(reopen_one_log)
Jul 4 07:21:28 everest-tns01 winbindd[3047096]: [2022/07/04 07:21:28.879790, 0] ../../source3/winbindd/winbindd.c:1722(main)
Jul 4 07:21:28 everest-tns01 winbindd[3047096]: winbindd version 4.15.7-TrueNAS started.
Jul 4 07:21:28 everest-tns01 winbindd[3047096]: Copyright Andrew Tridgell and the Samba Team 1992-2021
Jul 4 07:21:28 everest-tns01 winbindd[3047096]: [2022/07/04 07:21:28.879829, 0] ../../lib/util/util.c:212(directory_create_or_exist)
Jul 4 07:21:28 everest-tns01 winbindd[3047096]: [2022/07/04 07:21:28.879850, 0] ../../source3/lib/dumpcore.c:59(get_default_corepath)
Jul 4 07:21:28 everest-tns01 winbindd[3047096]: [2022/07/04 07:21:28.879867, 0] ../../source3/lib/dumpcore.c:256(dump_core_setup)
Jul 4 07:21:28 everest-tns01 winbindd[3047096]: [2022/07/04 07:21:28.879930, 0] ../../lib/util/util.c:212(directory_create_or_exist)
Jul 4 07:21:28 everest-tns01 winbindd[3047096]: directory_create_or_exist: mkdir failed on directory /var/db/system/samba4/private/msg.sock: No such file or directory
Jul 4 07:21:28 everest-tns01 systemd[1]: winbind.service: Main process exited, code=exited, status=1/FAILURE
Jul 4 07:21:28 everest-tns01 systemd[1]: winbind.service: Failed with result 'exit-code'.
Jul 4 07:21:28 everest-tns01 systemd[1]: Failed to start Samba Winbind Daemon.
Jul 4 07:21:28 everest-tns01 systemd[1]: Dependency failed for Samba SMB Daemon.
Jul 4 07:21:28 everest-tns01 systemd[1]: smbd.service: Job smbd.service/start failed with result 'dependency'.
Jul 4 07:21:28 everest-tns01 systemd[1]: Cannot find unit for notify message of PID 3047094, ignoring.
- AD Join
- 1 Pool created
- 2 Datasets
Thoughts?
