Truenas scale sending thousands request to 'dot' domain
mye
Recently I have created bridge on truenas scale with option -syncpeer to enable multicast for my homeassistance VM.
Now I see 65000+ requests per day from truenas ip (see screenshot). Homeassistance VM has different ip and i didn't see that behaviour when I was running it on dedicated hardware. Also "ix-truenas" isn't what I set form my host name. Have no idea where it coming from...
It doesn't look like normal behaviour too me.
morganL
Captain Morgan
Administrator
I'd suggest describing your IP addressing and bridge setup in more detail...
mye
Added screenshots of my network settings.
mye
tried with out -syncpeer - not much difference. ns request still going out just every 2 sec ish.. instead of every 1 sec.
eth0network
any root cause ? I have the same issue ... running TrueNAS-SCALE-22.02.4 !
found the issue using Pihole.
Daisuke
any root cause ?
Are you using the Pihole app? Then reach at @truecharts on their Discord channel. I personally would never use Pihole as Scale app on my home lab, I don't want my entire network to be affected if my Scale server is down. I do use Pihole externally on dual Raspberry Pis and I don't have any issues you mention, so is related to your network setup.
  • Like
Reactions: cap
