I have been messing around with TrueNAS Scale for a while, but I am now looking to using it as my home NAS solution. Bellow will be the hardware I am planning to use. My main use cases will be a network share that only I will use, as well as a Jellyfin/Plex server. The media will be a mixture of 480P-2160P content, all mkv files, I don't know off the top of my head what the encoding is. I will have syncthing running to sync files some files between my phone, tablet, TrueNAS (this machine), and maybe another TrueNAS System for a little redundancy. What is an optimal setup with what I have? The main concern I have is the cache. I had planned on using 2 4TB WD Drives, but reading some of the other posts, it sounds like that may actually hurt performance than help? Was also thinking of RaidZ1 or RaidZ2 (loosing 1 or 2 discs).
ZimaCube (N100)
4 Core N100 3.3Ghz
8GB DDR4 (I will likely upgrade this to 16GB)
256GB SSD (Will likely use this for boot)
5-6x 8TB Toshiba N300 HDDs
1-2x 4TB WD SN850X
Maybe an Intel Arc graphics card in future if needed for transcoding.
ZimaCube (N100)
4 Core N100 3.3Ghz
1-2x 4TB WD SN850X
