TrueNas Scale - iGPU allocation
T13nou
Hello guys !
Just a quick question regarding the Apps using GPU (in my case Intel iGPU).
I see that when I'm creating a new App template, Truenas proposes me multiple CPU allocation and I don't get the point...
I have only 1 GPU so in my mind it's on/off.
What does that mean exactly ? Is this somekind of multiplecores allocation ? More is more powerful ? 0 means no GPU allocated ?
If I assign 5 to one app, there is nothing less for another ?
Thanks for bringing me the light :D
I can't say for sure as it's not documented in a way that makes sense anywhere, but how I read it is that you have the possibility to assign some units of processing power from your iGPU... in your case you get 6 units.
Seems you can assign from 0 to 6 units to an app... no mention anywhere if that means you can't then assign more units to another app
