Hi all,
I'm new to TrueNAS and this is my first post, so I'm trying to add all information needed.
I've just finished my home-built server and think TrueNAS Scale will fit the best as per the information I've found.
When reading through the forum on some different thread I noticed that you refer "cache" to L2ARC.
I'm wondering if it will be worth to add the 2 NVMe drives as L2ARC or not? I saw a lot of discussions about minimum having 64GB ram which I´m above.
But as you see below I'm not quiet sure yet what the server will be used for, as it will be my first "real" server and I'm having some different ideas for the future and it will only be used by me and maybe up to 5 persons at the time maximum, but most of the time by only me.
As for the hardware this is the base setup that I'm having right now and it will be upgraded more in the future as I'm not aware of how much hardware I'll be needing for the upcoming year or two.
Mobo: MACHINIST ZX-DU99D4
CPU: 2 x Xeon E5-2640 v3
RAM: 128GB DDR4 ECC
SSD: 2 x Kingston A2000 1TB M.2 NVMe
HDD: 4 x Hitachi 2TB, 2 x WD 2TB (will be added more in the future when a controller card have been bought)
GPU: EVGA 1060 6GB
Ideas to add to the server:
Websites
Home Assistant
VM's
Cache server
Proxy server
Personal music server
Plex
VPN
Gaming server
Nextcloud
Thanks!
RAM: 128GB DDR4 ECC
GPU: EVGA 1060 6GB
Websites
Home Assistant
VM's
Cache server
Proxy server
Plex
VPN
Gaming server
Nextcloud
Thanks!
