Truenas Scale default certificate
kaushik
By default, TrueNAS scale comes equipped with an internal, self-signed certificate that enables encrypted access to the web interface.
(reference https://www.truenas.com/docs/scale/scaletutorials/credentials/certificates/certificatesscale/)
My question is what are the steps to use the default certificate on a Win 10 and the Truenas server, to get rid of the non-secure connection warnings?
Note I add the default certificate using this guide: https://windowsreport.com/install-windows-10-root-certificates/#2
Unfortunately, this did not work. So any pointer would be gratefully appreciated.
Thanks.
