Firebird99ta
- Sep 14, 2014
So, before I get into the issue I am having, here are the specs of my system:
Motherboard: Supermicro x11ssh
CPU: Intel E3-1245v5 4c/8t
Memory: 64gig Micron DDR4 2400 ECC
Hard Drives: 2-Western Digital Red 8tb 5460rpm 128meg cache CMR – Raid 1 mirror
2-Samsung 870 Evo 500gig 2.5” SSD Raid 1 mirror for Apps
2-PNY Optima 120gig mirrored boot drives.
Network Cards: Onboard Intel i210 1gb ethernet controller
Power supply is 600 watt 80+ Gold
Network Environment:
PFsense Appliance running Intel X550-t2 negotiating at 5g ISP connection. Then feeding 1-8port Gigabit Netgear Managed switch, which then splits to 2 more Gigabit Netgear Managed switch’s. All the switches are the same, allow for flow control, and 2 port binding. Various devices on the network from game systems, to workstations, to streaming appliances show no packet issues, collisions, dropped connections. No cabling issues. For all intensive purposes, a clean environment. No prior network issues, comm issues etc.
Onto the problem:
Supermicro has the current BIOS/BMC-IPMI firmware installed.
Truenas Scale is installed on the 120gig mirrored SSDs, with 16gig swap file, in UEFI mode. Boots normally and allows clean access with no problems.
Mounted the 2 Samsung SSDs and created a Dataset to store App data, configurations, backups Etc.
Mounted the 2 WD Red drives in an initial Mirror with multiple main Datasets, I.E. Documents, Music, Videos, Programs etc.
Whenever I try to copy data (Could be as little as 300mb, or as large as 30gigs) from either my workstation or VM server, Truenas locks up to the point I have to initiate a server reset through IPMI, or power off and reset,
The transfers will start out strong, and gradually fall off hitting 0mb transfer, causing windows to not be able to find to folder share, at that point browser shows searching for Truenas, and IPMI shows nothing out of the ordinary.
IPMI doesn’t show any alerts, systems issues, temp issues, cpu, nothing.
Ran memtest, memory checks fine. It’s running at 2133mhz which shouldn’t be a problem at all.
Steps I have used to try and solve the issue are as follows:
Swapped out the 64gig Micron for a 16gig Samsung stick. – Same issues.
Hooked up both 1gig Nic ports – Same issue.
Tried Network Flow control – Same issue.
Tried moving Truenas server to the same switch as either the workstation or VM server. – Same Issue
I don't see any threads here or on some of my other forums having this exact issue lest maybe worded differently.
What I am missing?
Onto the problem:
What I am missing?
