TrueNAS Scale 22.12.4 misreporting hard drive temperature (running hotter than the sun...)
FriedLemons
Hi all,
I recently upgraded to TrueNAS Scale 22.12.4 and since then my hard drive temperatures reported in the UI have been a little (read: a lot) wrong...
Here is my "Disk health" data:
Luckily no disk temperature related alerts!
If I look at a specific disk (sdc) I can see that before the update it was 31C and after the update it is 193274.97m C (which is hotter than the sun!)
According to the command line the temperature is 36 (assuming I'm reading this right)
# smartctl -a /dev/sdc | grep Temp
194 Temperature_Celsius 0x0022 064 055 000 Old_age Always - 36 (Min/Max 22/45)
All of my disks are behaving similarly so its not a specific brand/type of disk.
I googled around and couldn't find anyone else reporting this, its a fun on!
My system is:
TrueNAS-SCALE-22.12.4
Motherboard: Supermicro X9DRD-7LN4F-JBOD
CPU: 2x Intel(R) Xeon(R) CPU E5-2650 0 @ 2.00GHz 8C/16T
RAM: 64GB various, ECC
SSD: 2x
Crucial MX500 250GB
HDD: 2x Toshiba 8TB N300
HDD: 2x Seagate IronWolf 8 TB
I have two ZFS pools, the SSD's are mirrored and the HDD's are in RaidZ2
Let me know if there is anything else useful I can try. It looks to be an issue with Trunas reading/storing/processing the data incorrectly but I'm not sure what I can try.
FriedLemons
Thank you for letting me know. Sorry I couldn't find that by searching. Have a good day.
Sara
edit. ok is fixed :) require time to change:
FriedLemons
Mine are back to normal levels thank you:
PyCoder
Not fixed for me at all.
I'm on TrueNAS-SCALE-22.12.4.2 and one pool shows still "hotter then the sun" temps but not under "Reporting"
