Truenas not initiate
Hello, i instaled truenas core 13.0-U4, my hardware is
dell power edge t105
mobo - RR825 0RR825 CN-0RR825
processor - quad-core AMD Opteron.
ssd 240 gb
hdd 2x 10 tb
ram ddr2 8 gb
When the system initiate, it show me "starting devd", and not runned no more
jgreco
Resident Grinch
TrueNAS Core has a minimum memory requirement of 16GB. Does it work any better if you install another 8GB of RAM?
jgreco
Resident Grinch
Then your system may not be able to run TrueNAS CORE.
NugentS
Thats an old system and as @jgreco says it may not run TrueNAS.
However before you throw it out.
1. Make sure that you have gone through the system and updated all the various BIOS things that Dell have. It may be one of those thats killing you
2. Core will run in 8GB, its not overly enthusiastic about it - but it will run, though its not reccomended.
3. Try booting a FreeBSD LiveCD and see what it says - Core is FreeBSD under the hood and this may point you in a direction for a solution
4. Try an older version of TrueNAS - see if that boots
Good luck
