SnoppyFloppy
- Jun 17, 2021
Hi
Over the last month, TrueNAS have warned me a few times that it has found data corruption on my
Besides the iX-applications dataset the SSD pool also store a lot of personal data - which takes up far more space that iX-applications dataset - but only the iX-applications dataset have been affected by corruption. All apps however, continue to work.
Here is the output of zpool status -v. I was suprised to see that there was no checksum errors.
I have Truetool making backups every night and these are replicated to my other pool so I do have backups but as the errors have accumulated over time I wouldn't like to roll back unless it's absolutely necessary.
I'm on 22.02.4 now but all errors occurred while on 22.04.3
I'm no big expert in zfs so I really don't know what to do from here?
Hardware:
iX-applications/docker/... which resides on my SSD pool.Besides the iX-applications dataset the SSD pool also store a lot of personal data - which takes up far more space that iX-applications dataset - but only the iX-applications dataset have been affected by corruption. All apps however, continue to work.
admin@truenas:~$ sudo zpool status -v fast1
pool: fast1
state: ONLINE
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-8A
scan: scrub repaired 0B in 00:39:43 with 0 errors on Sun Sep 25 00:39:52 2022
NAME STATE READ WRITE CKSUM
fast1 ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
87c4023d-3a60-4754-a898-e3dfe191f714 ONLINE 0 0 0
16ada901-ebec-4318-9b87-c44ffb1d1578 ONLINE 0 0 0
fast1/ix-applications/docker/d7b1207cf6dfc4539216bb3b5b091a6979eab14a9b0bc5f6aa1b9a0cb475ae24-init:<0x0>
<0xd433>:<0x0>
<0x18d4e>:<0x0>
<0x25469>:<0x0>
fast1/ix-applications/docker/26fbd001165268ca4ed3a56bdd08d5560b901c351e4fcb4279fcee07cd7c96e0-init:<0x0>
fast1/ix-applications/docker/cba084459dd22ee7291c61b3daa5204f99bcea03add21b69a15902ecff44d7ec-init:<0x0>
fast1/ix-applications/docker/06fe6a99fbc5f83bf960e820351cc1e5c5cd362fbb4180734c3422ef133b605d-init:<0x0>
fast1/ix-applications/docker/caf2d0a081c08750a355c8494f15eb86ee1b5e55aa1818ab1b3767ad5dcb1a6a-init:<0x0>
fast1/ix-applications/docker/5cb33588e5493b9cf2bc9574bf09e126da1aba8580f8c26e83f79442a53c64c2-init:<0x0>
fast1/ix-applications/docker/98afae9a53d418aaaf8307c34b5cab1b0bc05a2c325f310019f8dd292ac8d727-init:<0x0>
<0x12cb>:<0x0>
<0xe6>:<0x0>
<0x12e9>:<0x0>
Hardware:
Supermicro X9DRH-7F 2x Xeon E5-2650v2 4x 32GB 1600 MHz ECC DDR3 ram (SK Hynix) boot pool: 2x Sandisk Plus 240GB (mirrored) fast1 pool: 2x Crusial MX500 1TB (mirrored) rust1 pool 2x Ironwolf Pro 8TB (mirrored) Nvidia GTX 1660 Ti Be Quiet! Straight Power 750
