Nov  8 01:53:28 torrenJail openvpn[2297]: SIGTERM[soft,ping-exit] received, process exiting
Nov  8 09:43:12 torrenJail openvpn[51707]: DEPRECATED OPTION: ncp-disable. Disabling cipher negotiation is a deprecated debug feature that will be removed in OpenVPN 2.6
Nov  8 09:43:12 torrenJail openvpn[51707]: DEPRECATED OPTION: --cipher set to 'AES-256-CBC' but missing in --data-ciphers (AES-256-GCM:AES-128-GCM). Future OpenVPN version will ignore --cipher for cipher negotiations. Add 'AES-256-CBC' to --data-ciphers or change --cipher 'AES-256-CBC' to --data-ciphers-fallback 'AES-256-CBC' to silence this warning.
Nov  8 09:43:12 torrenJail openvpn[51707]: WARNING: file 'client.key' is group or others accessible
Nov  8 09:43:12 torrenJail openvpn[51707]: WARNING: file '/configs/vpn-data/user.conf' is group or others accessible
Nov  8 09:43:12 torrenJail openvpn[51707]: Current Parameter Settings:
Nov  8 09:43:12 torrenJail openvpn[51707]:   config = '/configs/vpn-data/openvpn.ovpn'
Nov  8 09:43:12 torrenJail openvpn[51707]:   mode = 0
Nov  8 09:43:12 torrenJail openvpn[51707]:   show_ciphers = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   show_digests = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   show_engines = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   genkey = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   genkey_filename = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   key_pass_file = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   show_tls_ciphers = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   connect_retry_max = 0
Nov  8 09:43:12 torrenJail openvpn[51707]: Connection profiles [0]:
Nov  8 09:43:12 torrenJail openvpn[51707]:   proto = tcp-client
Nov  8 09:43:12 torrenJail openvpn[51707]:   local = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   local_port = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   remote = 'XXREMOTE_HOSTXX'
Nov  8 09:43:12 torrenJail openvpn[51707]:   remote_port = '443'
Nov  8 09:43:12 torrenJail openvpn[51707]:   remote_float = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   bind_defined = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   bind_local = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   bind_ipv6_only = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   connect_retry_seconds = 5
Nov  8 09:43:12 torrenJail openvpn[51707]:   connect_timeout = 120
Nov  8 09:43:12 torrenJail openvpn[51707]:   socks_proxy_server = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   socks_proxy_port = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   tun_mtu = 1500
Nov  8 09:43:12 torrenJail openvpn[51707]:   tun_mtu_defined = ENABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   link_mtu = 1500
Nov  8 09:43:12 torrenJail openvpn[51707]:   link_mtu_defined = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   tun_mtu_extra = 0
Nov  8 09:43:12 torrenJail openvpn[51707]:   tun_mtu_extra_defined = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   mtu_discover_type = -1
Nov  8 09:43:12 torrenJail openvpn[51707]:   fragment = 0
Nov  8 09:43:12 torrenJail openvpn[51707]:   mssfix = 1450
Nov  8 09:43:12 torrenJail openvpn[51707]:   explicit_exit_notification = 0
Nov  8 09:43:12 torrenJail openvpn[51707]:   tls_auth_file = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   key_direction = not set
Nov  8 09:43:12 torrenJail openvpn[51707]:   tls_crypt_file = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   tls_crypt_v2_file = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]: Connection profiles END
Nov  8 09:43:12 torrenJail openvpn[51707]:   remote_random = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   ipchange = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   dev = 'tun'
Nov  8 09:43:12 torrenJail openvpn[51707]:   dev_type = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   dev_node = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   lladdr = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   topology = 1
Nov  8 09:43:12 torrenJail openvpn[51707]:   ifconfig_local = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   ifconfig_remote_netmask = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   ifconfig_noexec = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   ifconfig_nowarn = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   ifconfig_ipv6_local = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   ifconfig_ipv6_netbits = 0
Nov  8 09:43:12 torrenJail openvpn[51707]:   ifconfig_ipv6_remote = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   shaper = 0
Nov  8 09:43:12 torrenJail openvpn[51707]:   mtu_test = 0
Nov  8 09:43:12 torrenJail openvpn[51707]:   mlock = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   keepalive_ping = 0
Nov  8 09:43:12 torrenJail openvpn[51707]:   keepalive_timeout = 0
Nov  8 09:43:12 torrenJail openvpn[51707]:   inactivity_timeout = 0
Nov  8 09:43:12 torrenJail openvpn[51707]:   inactivity_minimum_bytes = 0
Nov  8 09:43:12 torrenJail openvpn[51707]:   ping_send_timeout = 5
Nov  8 09:43:12 torrenJail openvpn[51707]:   ping_rec_timeout = 60
Nov  8 09:43:12 torrenJail openvpn[51707]:   ping_rec_timeout_action = 1
Nov  8 09:43:12 torrenJail openvpn[51707]:   ping_timer_remote = ENABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   remap_sigusr1 = 0
Nov  8 09:43:12 torrenJail openvpn[51707]:   persist_tun = ENABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   persist_local_ip = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   persist_remote_ip = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   persist_key = ENABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   passtos = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   resolve_retry_seconds = 1000000000
Nov  8 09:43:12 torrenJail openvpn[51707]:   resolve_in_advance = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   username = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   groupname = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   chroot_dir = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   cd_dir = '/configs/vpn-data/'
Nov  8 09:43:12 torrenJail openvpn[51707]:   writepid = '/var/run/openvpn.pid'
Nov  8 09:43:12 torrenJail openvpn[51707]:   up_script = '/configs/update-resolv-conf/update-resolv-conf.sh'
Nov  8 09:43:12 torrenJail openvpn[51707]:   down_script = '/configs/update-resolv-conf/update-resolv-conf.sh'
Nov  8 09:43:12 torrenJail openvpn[51707]:   down_pre = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   up_restart = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   up_delay = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   daemon = ENABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   inetd = 0
Nov  8 09:43:12 torrenJail openvpn[51707]:   log = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   suppress_timestamps = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   machine_readable_output = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   nice = 0
Nov  8 09:43:12 torrenJail openvpn[51707]:   verbosity = 4
Nov  8 09:43:12 torrenJail openvpn[51707]:   mute = 0
Nov  8 09:43:12 torrenJail openvpn[51707]:   gremlin = 0
Nov  8 09:43:12 torrenJail openvpn[51707]:   status_file = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   status_file_version = 1
Nov  8 09:43:12 torrenJail openvpn[51707]:   status_file_update_freq = 60
Nov  8 09:43:12 torrenJail openvpn[51707]:   occ = ENABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   rcvbuf = 0
Nov  8 09:43:12 torrenJail openvpn[51707]:   sndbuf = 0
Nov  8 09:43:12 torrenJail openvpn[51707]:   sockflags = 0
Nov  8 09:43:12 torrenJail openvpn[51707]:   fast_io = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   comp.alg = 0
Nov  8 09:43:12 torrenJail openvpn[51707]:   comp.flags = 0
Nov  8 09:43:12 torrenJail openvpn[51707]:   route_script = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   route_default_gateway = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   route_default_metric = 0
Nov  8 09:43:12 torrenJail openvpn[51707]:   route_noexec = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   route_delay = 5
Nov  8 09:43:12 torrenJail openvpn[51707]:   route_delay_window = 30
Nov  8 09:43:12 torrenJail openvpn[51707]:   route_delay_defined = ENABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   route_nopull = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   route_gateway_via_dhcp = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   allow_pull_fqdn = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   [redirect_default_gateway local=0]
Nov  8 09:43:12 torrenJail openvpn[51707]:   management_addr = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   management_port = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   management_user_pass = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   management_log_history_cache = 250
Nov  8 09:43:12 torrenJail openvpn[51707]:   management_echo_buffer_size = 100
Nov  8 09:43:12 torrenJail openvpn[51707]:   management_write_peer_info_file = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   management_client_user = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   management_client_group = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   management_flags = 0
Nov  8 09:43:12 torrenJail openvpn[51707]:   shared_secret_file = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   ciphername = 'AES-256-CBC'
Nov  8 09:43:12 torrenJail openvpn[51707]:   ncp_enabled = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   ncp_ciphers = 'AES-256-GCM:AES-128-GCM:AES-256-CBC'
Nov  8 09:43:12 torrenJail openvpn[51707]:   authname = 'SHA256'
Nov  8 09:43:12 torrenJail openvpn[51707]:   prng_hash = 'SHA1'
Nov  8 09:43:12 torrenJail openvpn[51707]:   prng_nonce_secret_len = 16
Nov  8 09:43:12 torrenJail openvpn[51707]:   keysize = 0
Nov  8 09:43:12 torrenJail openvpn[51707]:   engine = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   replay = ENABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   mute_replay_warnings = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   replay_window = 64
Nov  8 09:43:12 torrenJail openvpn[51707]:   replay_time = 15
Nov  8 09:43:12 torrenJail openvpn[51707]:   packet_id_file = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   test_crypto = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   tls_server = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   tls_client = ENABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   ca_file = 'ca.crt'
Nov  8 09:43:12 torrenJail openvpn[51707]:   ca_path = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   dh_file = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   cert_file = 'client.crt'
Nov  8 09:43:12 torrenJail openvpn[51707]:   extra_certs_file = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   priv_key_file = 'client.key'
Nov  8 09:43:12 torrenJail openvpn[51707]:   pkcs12_file = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   cipher_list = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   cipher_list_tls13 = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   tls_cert_profile = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   tls_verify = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   tls_export_cert = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   verify_x509_type = 0
Nov  8 09:43:12 torrenJail openvpn[51707]:   verify_x509_name = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   crl_file = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   ns_cert_type = 0
Nov  8 09:43:12 torrenJail openvpn[51707]:   remote_cert_ku = 65535
Nov  8 09:43:12 torrenJail openvpn[51707]:   remote_cert_ku = 0
Nov  8 09:43:12 torrenJail syslogd: last message repeated 14 times
Nov  8 09:43:12 torrenJail openvpn[51707]:   remote_cert_eku = 'TLS Web Server Authentication'
Nov  8 09:43:12 torrenJail openvpn[51707]:   ssl_flags = 0
Nov  8 09:43:12 torrenJail openvpn[51707]:   tls_timeout = 2
Nov  8 09:43:12 torrenJail openvpn[51707]:   renegotiate_bytes = -1
Nov  8 09:43:12 torrenJail openvpn[51707]:   renegotiate_packets = 0
Nov  8 09:43:12 torrenJail openvpn[51707]:   renegotiate_seconds = 3600
Nov  8 09:43:12 torrenJail openvpn[51707]:   handshake_window = 60
Nov  8 09:43:12 torrenJail openvpn[51707]:   transition_window = 3600
Nov  8 09:43:12 torrenJail openvpn[51707]:   single_session = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   push_peer_info = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   tls_exit = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   tls_crypt_v2_metadata = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   pkcs11_protected_authentication = DISABLED
Nov  8 09:43:12 torrenJail syslogd: last message repeated 15 times
Nov  8 09:43:12 torrenJail openvpn[51707]:   pkcs11_private_mode = 00000000
Nov  8 09:43:12 torrenJail openvpn[51707]:   pkcs11_cert_private = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   pkcs11_pin_cache_period = -1
Nov  8 09:43:12 torrenJail openvpn[51707]:   pkcs11_id = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   pkcs11_id_management = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   server_network = 0.0.0.0
Nov  8 09:43:12 torrenJail openvpn[51707]:   server_netmask = 0.0.0.0
Nov  8 09:43:12 torrenJail openvpn[51707]:   server_network_ipv6 = ::
Nov  8 09:43:12 torrenJail openvpn[51707]:   server_netbits_ipv6 = 0
Nov  8 09:43:12 torrenJail openvpn[51707]:   server_bridge_ip = 0.0.0.0
Nov  8 09:43:12 torrenJail openvpn[51707]:   server_bridge_netmask = 0.0.0.0
Nov  8 09:43:12 torrenJail openvpn[51707]:   server_bridge_pool_start = 0.0.0.0
Nov  8 09:43:12 torrenJail openvpn[51707]:   server_bridge_pool_end = 0.0.0.0
Nov  8 09:43:12 torrenJail openvpn[51707]:   ifconfig_pool_defined = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   ifconfig_pool_start = 0.0.0.0
Nov  8 09:43:12 torrenJail openvpn[51707]:   ifconfig_pool_end = 0.0.0.0
Nov  8 09:43:12 torrenJail openvpn[51707]:   ifconfig_pool_netmask = 0.0.0.0
Nov  8 09:43:12 torrenJail openvpn[51707]:   ifconfig_pool_persist_filename = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   ifconfig_pool_persist_refresh_freq = 600
Nov  8 09:43:12 torrenJail openvpn[51707]:   ifconfig_ipv6_pool_defined = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   ifconfig_ipv6_pool_base = ::
Nov  8 09:43:12 torrenJail openvpn[51707]:   ifconfig_ipv6_pool_netbits = 0
Nov  8 09:43:12 torrenJail openvpn[51707]:   n_bcast_buf = 256
Nov  8 09:43:12 torrenJail openvpn[51707]:   tcp_queue_limit = 64
Nov  8 09:43:12 torrenJail openvpn[51707]:   real_hash_size = 256
Nov  8 09:43:12 torrenJail openvpn[51707]:   virtual_hash_size = 256
Nov  8 09:43:12 torrenJail openvpn[51707]:   client_connect_script = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   learn_address_script = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   client_disconnect_script = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   client_config_dir = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   ccd_exclusive = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   tmp_dir = '/tmp'
Nov  8 09:43:12 torrenJail openvpn[51707]:   push_ifconfig_defined = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   push_ifconfig_local = 0.0.0.0
Nov  8 09:43:12 torrenJail openvpn[51707]:   push_ifconfig_remote_netmask = 0.0.0.0
Nov  8 09:43:12 torrenJail openvpn[51707]:   push_ifconfig_ipv6_defined = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   push_ifconfig_ipv6_local = ::/0
Nov  8 09:43:12 torrenJail openvpn[51707]:   push_ifconfig_ipv6_remote = ::
Nov  8 09:43:12 torrenJail openvpn[51707]:   enable_c2c = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   duplicate_cn = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   cf_max = 0
Nov  8 09:43:12 torrenJail openvpn[51707]:   cf_per = 0
Nov  8 09:43:12 torrenJail openvpn[51707]:   max_clients = 1024
Nov  8 09:43:12 torrenJail openvpn[51707]:   max_routes_per_client = 256
Nov  8 09:43:12 torrenJail openvpn[51707]:   auth_user_pass_verify_script = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   auth_user_pass_verify_script_via_file = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   auth_token_generate = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   auth_token_lifetime = 0
Nov  8 09:43:12 torrenJail openvpn[51707]:   auth_token_secret_file = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   port_share_host = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   port_share_port = '[UNDEF]'
Nov  8 09:43:12 torrenJail openvpn[51707]:   vlan_tagging = DISABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   vlan_accept = all
Nov  8 09:43:12 torrenJail openvpn[51707]:   vlan_pvid = 1
Nov  8 09:43:12 torrenJail openvpn[51707]:   client = ENABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   pull = ENABLED
Nov  8 09:43:12 torrenJail openvpn[51707]:   auth_user_pass_file = '/configs/vpn-data/user.conf'
Nov  8 09:43:12 torrenJail openvpn[51707]: OpenVPN 2.5.7 amd64-portbld-freebsd12.3 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Oct 21 2022
Nov  8 09:43:12 torrenJail openvpn[51707]: library versions: OpenSSL 1.1.1l-freebsd  24 Aug 2021, LZO 2.10
Nov  8 09:43:12 torrenJail openvpn[51708]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Nov  8 09:43:13 torrenJail openvpn[51708]: Control Channel MTU parms [ L:1623 D:1210 EF:40 EB:0 ET:0 EL:3 ]
Nov  8 09:43:13 torrenJail openvpn[51708]: Data Channel MTU parms [ L:1623 D:1450 EF:123 EB:406 ET:0 EL:3 ]
Nov  8 09:43:13 torrenJail openvpn[51708]: Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1571,tun-mtu 1500,proto TCPv4_CLIENT,cipher AES-256-CBC,auth SHA256,keysize 256,key-method 2,tls-client'
Nov  8 09:43:13 torrenJail openvpn[51708]: Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1571,tun-mtu 1500,proto TCPv4_SERVER,cipher AES-256-CBC,auth SHA256,keysize 256,key-method 2,tls-server'
Nov  8 09:43:13 torrenJail openvpn[51708]: TCP/UDP: Preserving recently used remote address: [AF_INET]212.0.0.0:443
Nov  8 09:43:13 torrenJail openvpn[51708]: Socket Buffers: R=[65536->65536] S=[32768->32768]
Nov  8 09:43:13 torrenJail openvpn[51708]: Attempting to establish TCP connection with [AF_INET]212.0.0.0:443 [nonblock]
Nov  8 09:43:13 torrenJail openvpn[51708]: TCP connection established with [AF_INET]212.0.0.0:443
Nov  8 09:43:13 torrenJail openvpn[51708]: TCP_CLIENT link local: (not bound)
Nov  8 09:43:13 torrenJail openvpn[51708]: TCP_CLIENT link remote: [AF_INET]212.0.0.0:443
Nov  8 09:43:13 torrenJail openvpn[51708]: TLS: Initial packet from [AF_INET]212.0.0.0:443, sid=360a5683 51b99176
Nov  8 09:43:13 torrenJail openvpn[51708]: VERIFY OK: depth=1, C=RO, L=Bucharest, O=CyberGhost S.A., CN=CyberGhost Root CA, emailAddress=info@cyberghost.ro
Nov  8 09:43:13 torrenJail openvpn[51708]: VERIFY KU OK
Nov  8 09:43:13 torrenJail openvpn[51708]: Validating certificate extended key usage
Nov  8 09:43:13 torrenJail openvpn[51708]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Nov  8 09:43:13 torrenJail openvpn[51708]: VERIFY EKU OK
Nov  8 09:43:13 torrenJail openvpn[51708]: VERIFY OK: depth=0, CN=dallas-rack409.nodes.gen4.ninja
Nov  8 09:43:14 torrenJail openvpn[51708]: WARNING: 'link-mtu' is used inconsistently, local='link-mtu 1571', remote='link-mtu 1555'
Nov  8 09:43:14 torrenJail openvpn[51708]: WARNING: 'keysize' is used inconsistently, local='keysize 256', remote='keysize 128'
Nov  8 09:43:14 torrenJail openvpn[51708]: Control Channel: TLSv1.3, cipher TLSv1.3 TLS_AES_256_GCM_SHA384, peer certificate: 4096 bit RSA, signature: RSA-SHA256
Nov  8 09:43:14 torrenJail openvpn[51708]: [dallas-rack409.nodes.gen4.ninja] Peer Connection Initiated with [AF_INET]212.0.0.0:443
Nov  8 09:43:14 torrenJail openvpn[51708]: PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,route-ipv6 2000::/3,dhcp-option DNS 10.0.0.243,route-gateway 10.16.5.1,topology subnet,ifconfig 10.16.5.216 255.255.255.0,peer-id 0'
Nov  8 09:43:14 torrenJail openvpn[51708]: WARNING: You have specified redirect-gateway and redirect-private at the same time (or the same option multiple times). This is not well supported and may lead to unexpected results
Nov  8 09:43:14 torrenJail openvpn[51708]: OPTIONS IMPORT: --ifconfig/up options modified
Nov  8 09:43:14 torrenJail openvpn[51708]: OPTIONS IMPORT: route options modified
Nov  8 09:43:14 torrenJail openvpn[51708]: OPTIONS IMPORT: route-related options modified
Nov  8 09:43:14 torrenJail openvpn[51708]: OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Nov  8 09:43:14 torrenJail openvpn[51708]: OPTIONS IMPORT: peer-id set
Nov  8 09:43:14 torrenJail openvpn[51708]: OPTIONS IMPORT: adjusting link_mtu to 1626
Nov  8 09:43:14 torrenJail openvpn[51708]: Outgoing Data Channel: Cipher 'AES-256-CBC' initialized with 256 bit key
Nov  8 09:43:14 torrenJail openvpn[51708]: Outgoing Data Channel: Using 256 bit message hash 'SHA256' for HMAC authentication
Nov  8 09:43:14 torrenJail openvpn[51708]: Incoming Data Channel: Cipher 'AES-256-CBC' initialized with 256 bit key
Nov  8 09:43:14 torrenJail openvpn[51708]: Incoming Data Channel: Using 256 bit message hash 'SHA256' for HMAC authentication
Nov  8 09:43:14 torrenJail openvpn[51708]: ROUTE_GATEWAY 192.168.0.1/255.255.255.0 IFACE=epair0b HWADDR=02:0e:c6:57:0d:2d
Nov  8 09:43:14 torrenJail openvpn[51708]: GDG6: remote_host_ipv6=n/a
Nov  8 09:43:14 torrenJail openvpn[51708]: GDG6: problem writing to routing socket: No such process (errno=3)
Nov  8 09:43:14 torrenJail openvpn[51708]: ROUTE6: default_gateway=UNDEF
Nov  8 09:43:14 torrenJail openvpn[51708]: TUN/TAP device /dev/tun0 opened
Nov  8 09:43:14 torrenJail openvpn[51708]: do_ifconfig, ipv4=1, ipv6=0
Nov  8 09:43:14 torrenJail openvpn[51708]: /sbin/ifconfig tun0 10.16.5.216 10.16.5.1 mtu 1500 netmask 255.255.255.0 up
Nov  8 09:43:14 torrenJail openvpn[51708]: /sbin/route add -net 10.16.5.0 10.16.5.1 255.255.255.0
Nov  8 09:43:14 torrenJail openvpn[51708]: /configs/update-resolv-conf/update-resolv-conf.sh tun0 1500 1626 10.16.5.216 255.255.255.0 init
Nov  8 09:43:19 torrenJail openvpn[51708]: /sbin/route add -net 212.0.0.0 192.168.0.1 255.255.255.255
Nov  8 09:43:19 torrenJail openvpn[51708]: /sbin/route add -net 0.0.0.0 10.16.5.1 128.0.0.0
Nov  8 09:43:19 torrenJail openvpn[51708]: /sbin/route add -net 128.0.0.0 10.16.5.1 128.0.0.0
Nov  8 09:43:19 torrenJail openvpn[51708]: WARNING: OpenVPN was configured to add an IPv6 route. However, no IPv6 has been configured for tun0, therefore the route installation may fail or may not work as expected.
Nov  8 09:43:19 torrenJail openvpn[51708]: add_route_ipv6(2000::/3 -> :: metric -1) dev tun0
Nov  8 09:43:19 torrenJail openvpn[51708]: /sbin/route add -inet6 2000::/3 -iface tun0
Nov  8 09:43:19 torrenJail openvpn[51708]: WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Nov  8 09:43:19 torrenJail openvpn[51708]: Initialization Sequence Completed
Nov  8 09:44:58 torrenJail openvpn[51708]: [ACTUAL.VPN.SUBHOST.com] Inactivity timeout (--ping-exit), exiting
Nov  8 09:44:58 torrenJail openvpn[51708]: TCP/UDP: Closing socket
Nov  8 09:44:58 torrenJail openvpn[51708]: /sbin/route delete -net 212.0.0.0 192.168.0.1 255.255.255.255
Nov  8 09:44:58 torrenJail openvpn[51708]: /sbin/route delete -net 0.0.0.0 10.16.5.1 128.0.0.0
Nov  8 09:44:58 torrenJail openvpn[51708]: /sbin/route delete -net 128.0.0.0 10.16.5.1 128.0.0.0
Nov  8 09:44:58 torrenJail openvpn[51708]: delete_route_ipv6(2000::/3)
Nov  8 09:44:58 torrenJail openvpn[51708]: /sbin/route delete -inet6 2000::/3 -iface tun0
Nov  8 09:44:58 torrenJail openvpn[51708]: Closing TUN/TAP interface
Nov  8 09:44:58 torrenJail openvpn[51708]: /sbin/ifconfig tun0 destroy
Nov  8 09:44:58 torrenJail openvpn[51708]: /configs/update-resolv-conf/update-resolv-conf.sh tun0 1500 1626 10.16.5.216 255.255.255.0 init
Nov  8 09:44:58 torrenJail openvpn[51708]: SIGTERM[soft,ping-exit] received, process exiting
