TrueNAS installation fails: CANT_FIND_sdb3_OR_sdbp3: not a block device
jammydammy
So i wanna install the current version of TrueNAS Scale on my old HP Compaq 8100 Elite (around 2010) for Backups from Proxmox. At first i had Trouble to boot in the installer at all. I fixed that using i HP Bios-Update from v01.05 to v01.13. Now i get the error "lsblk: CANT_FIND_sdb3_OR_sdbp3: not a block device". I search all forums i could find but could find a solution. It would be super great if someone would be able to help me on this hellride of TrueNAS installation.
Error:
The TrueNAS installation on sdb has failed. Press enter to contiue ...
SPECS
PC: HP Compaq 8100 Elite (around 2010)
Intel core i 5 660
RAM: 12GB
MoBo: HP motherboard from 2010 SN: PAMEE0ED6ZN1198
Ssd - BootDrive: Verbatim 256 Gb (New) directly connected to the MoBo using SATA
HDD: 3x1TB Hitachi NAS Drives
Bios – HP v01.13: does not support uefi or efi. Only Bios
Installation medium: 64GB Intenso 3.2 USB-Flashdrive
TrueNAS – Scale version: 23.10.2
STEPS I TOOK:
Bios boot mode
Motherboard controller set to AHCI
dd if=/dev/zero of=/dev/sdi bs=1M
sed –i '/parted/a sleep 20' /usr/sbin/truenas-install
Bios update form 1.05v to 1.13v using win 7 installed fine after it had some trouble finding the drivers at some point it found them by itself. I dont know why.
Used iso and dd mode in rufus
Used balena etcher
Used ventoy to boot from
Install trueNAS core (13.0 – U6) - wont boot at all
Made sure i did everything correctly using this guide:
https://www.truenas.com/docs/scale/gettingstarted/install/installingscale/
Regards
Jammy
When i choose EFI installation mode it installs fine, but wont boot afterwards because my mobo doesnt support uefi
