I'm running TrueNAS Core 12 on a Dell R720xd. I have 12 drives in the system, 5.46TB, so I have a total of about 65TB. I have a separate 256GB SSD for the OS storage and boot.
Intel(R) Xeon(R) CPU E5-2665 0 @ 2.40GHz x 2
256 GB of RAM
I set a lot of this up based on some research, reading these forums. I am just curious and looking things over again.
I have 2 pools.
vdev0 - RAIDZ2 - 21TB
vdev1 - RADZ2 - 21TB
Mostly defaults on those pools, lz4 compression, dedup off.
I have a dataset on vdev0 with an NFS share.
I have a zvol on vdev1 at almost 17TB (80%) with an iscsi share in disk mode.
I have a dedicated fiber NIC that is the share for the iscsi with a second R730 Dell server running my proxmox. I share the iscsi over a cable to cable network on the fiber line. The NFS is shared across the main network and goes through the switch.
I use the NFS for VM images, so ISO files, and also backups. I use the iscsi primarily to store video files for my Plex server.
I have read about pitfalls of raidz2 vs mirrors when it comes to iscsi, but I have not had any performance issues up to this point. The NFS volume works just fine as well.
I guess my question is did I choose a decent setup? I know I got have just done one large NFS and it most likely would have been fine, thinking I should have, but I wanted to play with iscsi, the separate NICS, get that traffic off the switch, etc...
I'm using about 8TB of the 17TB on the iscsi at this point, kinda worried about when I want to take away from the NFS vdev0 and add more storage to iscsi, not sure how to do that or if it's possible, not researched that yet.
I didn't want to do mirrors because I was willing to give on some performance for more storage. This is generally just home usage at this point, so a couple of TV's running, maybe 1 person remote at times, nothing major.
All the compute, local storage, buffer cache, is all on the second server, the R730, so this R720 and TrueNAS is just doing storage.
I was curious about the 80% thing as well. Was I supposed to do that on the zvol or fill that up and just monitor my actual storage from proxmox? I think I did it right on the zvol, but wasn't sure.
Also curious about expanding things and if I made some bad mistakes along the way.
Thanks!
David
256 GB of RAM
I have 2 pools.
Thanks!
David
