New to the forum and TrueNAS. I wanted a low power little 4 bay NAS unit to just act as a simple file store. So too the approach of a low power embedded mITX mother board etc as per the list below:
MB - ASRock with Intel J3710 CPU https://www.asrock.com/mb/Intel/J3710-ITX/index.us.asp#Specification
CPU - Intel® Quad-Core Pentium® Processor J3710 (up to 2.64 GHz)
RAM - 2 x DDR3L SO-DIMM slot with 8GB RAM per slot: total installed 16GB DDR3L 1600/1066 non-ECC, un-buffered memory
Chassis / Powersupply - Innovision with 200w PS https://www.aliexpress.com/item/1005001626893532.html?spm=a2g0s.9042311.0.0.27424c4dyFYhPP
Boot Disk - New Adsyncetek SSD eUSB 16GB DOM SSD 9PIN pitch 2.54mm Industrial Embedded USB Disk on Module (EUSB DOM) https://www.aliexpress.com/item/1005002804457739.html?spm=a2g0s.9042311.0.0.27424c4dyFYhPP
I know memory should be ECC but will not be running this very hard and was going for compact / low power
TrueNAS core installed to eUSB DOM no problem but when system runs up the middleware fails to load.
While the MB does have a PCIe 2.0x1 slot and I could install an SSD adapter I'm thinking of trying to install the USB 3.0 adapter to the motherboard header and then use a Scandisk 32GB Ultra Fit USB 3.1 Flash Drive as the boot drive first. https://www.aliexpress.com/item/1005002977827879.html?spm=a2g0s.9042311.0.0.27424c4dSdvbCg
If I could find a 1/2 size mini PCIe DOM like the Innodisk I'd use that but not sure they exist https://www.innodisk.com/en/products/flash-storage/mini-pciedom/mini_pciedom_1me3
Anyway .. I thought I'd ask to see if anyone can suggest what I could try to get the current USB 2.0 DOM approach to work as its close to being operational if I could just get the middleware to load.
thanks
- "MIDDLEWARE FAILED TO START WITHIN 4 MINUTES, SYSTEM WILL NOT BEHAVE CORRECTLY!!"
- Freenas continues to run to complete successful boot, but I also get the following messages: Failed to run middleware call. Daemon not running?
thanks
