Neko77025
- Mar 6, 2017
First off, I know this is be A oddity.
So, I have A home server , use it for Plex, VMs, Game hosting ect ect. Been using Windows Storage Spaces for years (with out issues). However, had A disk fail and first time Storage Spaces would not rebuild for me ( But no data loss ). So, I wanted to Setup Truenas as VM inside windows .. just to test it out , not even sure if it would work. (Did not want TrueNas as a host becuase it wont do GPU transcoding)
Anyhow .. Have done some test setups. And can get it to work. When I transfer to or from the windows SMB I get full Gigabit 113 MB/s (so network is my bottleneck).
The issue, I am having is .. When I map it as Network Drive and give that info to plex. Play back is crazy bad. Plex shows it almost as Network issues.
Is this A Plex issue, TrueNas issue, User Issue, Usecase issue ?
also, if I do get this working as intended. Am I missing any unforeseen issues ... (is this a bad idea) ?
TrueNAS is running in A VM (Windows 10 HyperV)
CPU Giving it 6 Threads (I9-10900)
RAM ( Allocated 16,384 GB, dynamic memory is off ) DDR4 3200Mhz
HDDs ( 5x HGST Ultrastar 7K6000 HUS726060ALE610 6TB )
OS Drive ( Virtual Disk, 120gb) (this is located on 2x MX500 250gb (Storage Spaces) MIRRORed
NIC ( Intel 82576 )
Notes:
HDDs are offline in host for HyperV SCSI passthrew.
HDDs are using the 5x Sata ports on Motherboard (Asus Prime Z590M-Plus)
Z2 setup
HOST Specs.
Windows 10 Pro
CPU : i9 10900 10core
GPU1: Intel 630 (Igpu) Prime Display + Quick Sync Use.
GPU2: Quadro P400 (only used for plex Transcode)
M.B. : Asus Prime Z590M-Plus
RAM: 64Gb 4x 16gb 3200Mhz G.Skill Aegis
PSU : Evga G6 750w
HBA: LSI 9207-8i
NIC # 2 : Dual RJ45 Intel 82576 (PCIe x1)
OS Drve: ADATA sx8200 Pro 1tb
Other Drives:
5x HGST Ultrastar 7K6000 HUS726060ALE610 6TB (sata motherboard)
2x 500gb PNY C900 SSD (HBA)
2x MX500 250gb SSD (HBA)
2x 4Tb HGST Ultrastar (HUS724040ALE641) (HBA)
1x 8TB Ironwolf NAS (HBA) (this is Hotsawp bay)
NIC ( Intel 82576 )
Notes:
Z2 setup
HOST Specs.
Windows 10 Pro
PSU : Evga G6 750w
HBA: LSI 9207-8i
Other Drives:
