TrueNAS-22.02.2 -> TrueNAS-22.02.3 - data pool fails to mount
Sean Hafeez
Very simple. Single pool. Update from 22.02.2 to 22.02.3.
System reboots, the pool is not mounted on boot. GUI shows it missing. If you click import in GUI it does not show the pool. I can import the pool from the command line just fine, everything works. On reboot same issue. Reboot is either by CLI or GUI, it makes no difference).
indivision
I'm probably not best to troubleshoot this one. But, I think everyone will want/need to know your hardware setup to help.
morganL
Captain Morgan
Administrator
TRUENAS-MINI-3.0-XL+
Mighty fine hardware... surprised that you have the issue. No other similar reports I know of.
Can you rollback and re-import the pool?
You are welcome to report-a-bug when you want to work with someone. Let us know the BugID.
Sean Hafeez
Filed bug.
Sean Hafeez
Filed bug.
Resolved for unknown reason. Rebooted into 22.02.3 to get debug file and it works now. Only change from being able to reproduce this was that back under 22.02.2 I cleaned up old snapshots and removed a few datasets before rebooting into 22.02.3 again.
morganL
Captain Morgan
Administrator
Your problem may be resolved (great!), but the behaviour indicates a bug with respect to numbers of snapshot or something similar?
Was the pool close to being full?
Top Bottom
