RodrigoLopes
- Feb 2, 2019
Hello All,
I just did an upgrade from version 22.02.3 to the latest patch/version 22.02.4.
As normal i backed up everything and initiated the upgrade.
As soon as the download and install finished Truenas prompted that it would reboot, so far everything ok.
Then after 10minutes i still wasn't able to reach the GUI.
I went to the "DC" and as soon as i got there i saw the DISK LED all on without flashing and no output on the monitor.
I waited for 30 minutes and the situation presisted. I tried the reset button and no change. After all failed attemps, around 1 hour i decided to pull the plug.
Now it won't boot or give me a post.
I will try connecting a monitor with HDMI instead of the one i'm using with an adapter from HDMI to VGA. But i don't believe i will see anydiference in behavior.
Has anyone tried to upgrade and had the same issue?
Best regards,
Rodrigo
Best regards,
Rodrigo
