Lansing123
- Oct 4, 2021
Hello, I have tried to update truenas scale but i am unable too. I only get an error that sais "FAILED" i have the full log further down. I am trying to update from TrueNAS-SCALE-22.02.0.1 too TrueNAS-22.02.3. I was unable to update to TrueNAS-22.02.2 when i tried before too. I have both tried automatic update, and downloading the file manually and uploading it. Does anyone have a clue on what's happening?
Hardware:
CPU: Intel(R) Core(TM) i7-9700 CPU @ 3.00GHz
RAM: DDR4 (None ECC) 32GB
Motherboard: Asus WS C246M PRO Series
Boot Drive: Samsung 980 NVMe 250GB
Data drives: 10x 8TB raid2z different models. (8x Toshiba 2x WD red)
No harddisk controller
Network card that is on the motherboard
Error: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/plugins/update_/utils_linux.py", line 18, in mount_update subprocess.run(["mount", "-t", "squashfs", "-o", "loop", path, mounted], **run_kw) File "/usr/lib/python3.9/subprocess.py", line 528, in run raise CalledProcessError(retcode, process.args, subprocess.CalledProcessError: Command '['mount', '-t', 'squashfs', '-o', 'loop', '/var/tmp/firmware/manualupdate.tar', '/tmp/tmp0ubpniv3']' returned non-zero exit status 1. During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/job.py", line 423, in run await self.future File "/usr/lib/python3/dist-packages/middlewared/job.py", line 459, in __run_body rv = await self.method(*([self] + args)) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1261, in nf return await func(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/update.py", line 412, in file await self.middleware.call('update.install_manual_impl', job, destfile, dest_extracted) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1318, in call return await self._call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1286, in _call return await self.run_in_executor(prepared_call.executor, methodobj, *prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1186, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) File "/usr/lib/python3.9/concurrent/futures/thread.py", line 52, in run result = self.fn(*self.args, **self.kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/update_/install_linux.py", line 23, in install_manual_impl self._install( File "/usr/lib/python3/dist-packages/middlewared/plugins/update_/install_linux.py", line 34, in _install with mount_update(path) as mounted: File "/usr/lib/python3.9/contextlib.py", line 117, in __enter__ return next(self.gen) File "/usr/lib/python3/dist-packages/middlewared/plugins/update_/utils_linux.py", line 20, in mount_update raise CallError(f"Invalid update image file. Please, re-download update. Error: {e.stdout}") middlewared.service_exception.CallError: [EFAULT] Invalid update image file. Please, re-download update. Error:
Hardware:
