So I have been hesitant to upgrade my trusty FreeNAS machine to TrueNAS 12, even though it would bring a couple of features I'd like (most notably native encryption and encrypted replication). I thought I would check it out on a spare machine and also run some tests and benchmarks with the encryption...
The system I used is a Dell Poweredge R420, with a single E5-2403 CPU, 48G RAM and 4 2TB SATA 5400rpm drives.
I never got around to running tests with encryption, because no matter what I try I can't get decent read speeds with TrueNAS 12. I have run various pool configurations (4-way stripe, 2 mirror pairs, RAIDZ1) and various simple tests (dd, cat > /dev/null, iozone, scrubs). They all result in only about 40-50MB/s per drive read speed, while on FreeNAS 11 it's > 100MB/s per drive. Write speeds on the other hand is about the same...
As an example, this is a dd test with a 4-way striped pool, compression and encryption off. All default settings.
FreeNAS 11.3U5:
root@freenas[/mnt/testpool/plain]# dd if=/dev/zero of=test.bin bs=1M count=100000
100000+0 records in
100000+0 records out
104857600000 bytes transferred in 216.760091 secs (483749567 bytes/sec)
root@freenas[/mnt/testpool/plain]# dd of=/dev/null if=test.bin bs=1M count=100000
100000+0 records in
104857600000 bytes transferred in 230.173066 secs (455559817 bytes/sec)
TrueNAS 12U1 (upgraded, same exact pool):
100000+0 records in
104857600000 bytes transferred in 229.388011 secs (457118920 bytes/sec)
100000+0 records in
104857600000 bytes transferred in 503.398958 secs (208299199 bytes/sec)
I also tried TrueNAS scale alpha with very similar results, maybe this is a OpenZFS 2.0 issue?
Any ideas what I could try to get my linear read speed back so I can maybe run TrueNAS 12?
FreeNAS 11.3U5:
100000+0 records in
100000+0 records in
100000+0 records in
100000+0 records in
