Current setup: I have a 36 bay Supermicro running Freenas 9.10. Currently only 12 of the bays are full, and using a single M1015 card flashed to IT mode. It serves VMs to ESXi via iSCSI over 10GbE Intel FC as well as SMB/NFS publically available over the intel 1Gb nics on the motherboard. I have 96Gb ram which may be overkill, since it's completely dedicated to ZFS. Each of the drives is a WD4TB Red NAS, with a current total usable of 24Tb, but I only allocated 12Tb in order to keep ZFS under 50% utilization due to using iSCSI.
I setup the 12 drives in a raid 10 setup, just a bunch of mirrors.
I should mention this is more of a homelab than a production environment, but I do try to follow good practices so long as it makes financial sense to do so.
I was looking at upgrading my storage, and to try to improve performance. I think my current storage isn't performing to capacity, just from local tests, but my testing methods could be wrong, so I'm posting here to doublecheck.
First I tested using what I found http://louwrentius.com/74tb-diy-nas-based-on-zfs-on-linux.html and the results are below.
But I've been informed I should be testing with rsync and a ramdisk for more realistic results. So I created and mounted a ramdisk on /mnt/temp using the following command:
But this performance seems below what I should be able to get from 6 spindles of WD Red 4TB drives, at least half as much.
I did see the commands referenced here regarding testing performance, so their output is below.
So, the questions I have:
1. Which test is the most accurate?
2. I'm currently using only a single M1015 in IT mode to support these drives connected to a backplane. Am I hitting capacity of the card maybe?
3. It looks like my ARC hit ratio never exceeds 88.4%, is there anything to do to tune it? It starts out slow at about 60% on boot and then rises up over a few days. Possibly too much ram?
zpool status
output below:Code:
pool: Poolbase state: ONLINE scan: scrub repaired 0 in 2h29m with 0 errors on Sat Apr 15 04:29:35 2017 config: NAME STATE READ WRITE CKSUM Poolbase ONLINE 0 0 0 mirror-0 ONLINE 0 0 0 gptid/5e62dcdd-0ff8-11e5-9352-0025902afba2 ONLINE 0 0 0 gptid/5ee03eb0-0ff8-11e5-9352-0025902afba2 ONLINE 0 0 0 mirror-1 ONLINE 0 0 0 gptid/5f65db21-0ff8-11e5-9352-0025902afba2 ONLINE 0 0 0 gptid/5fed5d33-0ff8-11e5-9352-0025902afba2 ONLINE 0 0 0 mirror-2 ONLINE 0 0 0 gptid/606fab56-0ff8-11e5-9352-0025902afba2 ONLINE 0 0 0 gptid/60f2bae5-0ff8-11e5-9352-0025902afba2 ONLINE 0 0 0 mirror-3 ONLINE 0 0 0 gptid/618a6630-0ff8-11e5-9352-0025902afba2 ONLINE 0 0 0 gptid/96afa2a2-9272-11e6-8020-0025902afba2 ONLINE 0 0 0 mirror-4 ONLINE 0 0 0 gptid/62a67e32-0ff8-11e5-9352-0025902afba2 ONLINE 0 0 0 gptid/63404443-0ff8-11e5-9352-0025902afba2 ONLINE 0 0 0 mirror-5 ONLINE 0 0 0 gptid/63cc4aad-0ff8-11e5-9352-0025902afba2 ONLINE 0 0 0 gptid/64569a29-0ff8-11e5-9352-0025902afba2 ONLINE 0 0 0
[root@freenas /mnt/Poolbase]# dd if=/dev/zero of=test.bin bs=1M count=100000 100000+0 records in 100000+0 records out 104857600000 bytes transferred in 37.415629 secs (2802508017 bytes/sec) [root@freenas /mnt/Poolbase]# dd if=test.bin of=/dev/null bs=1M 100000+0 records in 100000+0 records out 104857600000 bytes transferred in 19.719403 secs (5317483488 bytes/sec)
mdmfs -s 10G md1 /mnt/temp/
and then ran test by copying an iso to and from it, per below.Code:
[root@freenas /mnt/Poolbase/Temp4now]# rsync en_windows_10_enterprise_2016_ltsb_x86_dvd_9060010.iso /mnt/temp/ --progress en_windows_10_enterprise_2016_ltsb_x86_dvd_9060010.iso 2,642,147,328 100% 170.37MB/s 0:00:14 (xfr#1, to-chk=0/1) [root@freenas /mnt/Poolbase/Temp4now]# rsync /mnt/temp/en_windows_10_enterprise_2016_ltsb_x86_dvd_9060010.iso en.iso --progress en_windows_10_enterprise_2016_ltsb_x86_dvd_9060010.iso 32,768 0% 0.00kB/s 0:00:00 2,642,147,328 100% 175.75MB/s 0:00:14 (xfr#1, to-chk=0/1)
[root@freenas /mnt/Poolbase/Temp4now]# dd if=/dev/zero of=tmp.dat bs=2048k count =50k 51200+0 records in 51200+0 records out 107374182400 bytes transferred in 277.660321 secs (386710575 bytes/sec) [root@freenas /mnt/Poolbase/Temp4now]# dd if=tmp.dat of=/dev/null bs=2048k count =50k 51200+0 records in 51200+0 records out 107374182400 bytes transferred in 152.828701 secs (702578650 bytes/sec)
