Have the mibs changed with TrueNAS 12?
zpoolReadOps1sec OBJECT-TYPE SYNTAX Counter64 MAX-ACCESS read-only STATUS current DESCRIPTION "The number of read I/O operations sent to the pool or device, including metadata requests (over 1 second interval)." ::= { zpoolEntry 12 } zpoolWriteOps1sec OBJECT-TYPE SYNTAX Counter64 MAX-ACCESS read-only STATUS current DESCRIPTION "The number of write I/O operations sent to the pool or device (over 1 second interval)." ::= { zpoolEntry 13 } zfsArcSize OBJECT-TYPE SYNTAX Gauge32 MAX-ACCESS read-only STATUS current DESCRIPTION "" ::= { arc 1 } zfsL2ArcSize OBJECT-TYPE SYNTAX Gauge32 MAX-ACCESS read-only STATUS current DESCRIPTION "" ::= { l2arc 5 }
diff
output between the 12.0-BETA and 11.3-U3.2 FREENAS-MIB.txts shows the changes are mostly to MIBs for device temps:10c10 < LAST-UPDATED "202005280000Z" --- > LAST-UPDATED "201905120000Z" 19c19 < REVISION "202005280000Z" --- > REVISION "201905120000Z" 327,328c327 < zvolAvailable Integer32, < zvolReferenced Integer32 --- > zvolAvailable Integer32 380,387d378 < zvolReferenced OBJECT-TYPE < SYNTAX Integer32 (0..2147483647) < MAX-ACCESS read-only < STATUS current < DESCRIPTION < "" < ::= { zvolEntry 7 } < 573,619d563 < hddTempTable OBJECT-TYPE < SYNTAX SEQUENCE OF HDDTempEntry < MAX-ACCESS not-accessible < STATUS current < DESCRIPTION < "Table of HDDs and their temperatures." < ::= { freeNas 3 } < < hddTempEntry OBJECT-TYPE < SYNTAX HDDTempEntry < MAX-ACCESS not-accessible < STATUS current < DESCRIPTION < "An entry containing a HDD and its temperature." < INDEX { hddTempIndex } < ::= { hddTempTable 1 } < < HDDTempEntry ::= SEQUENCE { < hddTempIndex Integer32, < hddTempDevice DisplayString, < hddTempValue Gauge32 < } < < hddTempIndex OBJECT-TYPE < SYNTAX Integer32 (0..65535) < MAX-ACCESS read-only < STATUS current < DESCRIPTION < "Reference index for each observed HDD." < ::= { hddTempEntry 1 } < < hddTempDevice OBJECT-TYPE < SYNTAX DisplayString < MAX-ACCESS read-only < STATUS current < DESCRIPTION < "The name of the HDD we are reading temperature from." < ::= { hddTempEntry 2 } < < hddTempValue OBJECT-TYPE < SYNTAX Gauge32 < MAX-ACCESS read-only < STATUS current < DESCRIPTION < "The temperature of this HDD in mC." < ::= { hddTempEntry 3 } <
[root@zabbix ~]# snmptranslate -On FREENAS-MIB::zfsArcC .1.3.6.1.4.1.50536.1.4.6
[root@zabbix ~]# snmpwalk -v 2c -c public 192.168.40.40 FREENAS-MIB::zfsArcC FREENAS-MIB::zfsArcC = No Such Object available on this agent at this OID
I built a complete new Zabbix VMTry removing and reimporting the FREENAS-MIB.
[root@zabbix ~]# snmpwalk -v 2c -c public 192.168.40.40 IF-MIB::ifDescr IF-MIB::ifDescr.1 = STRING: ix0 IF-MIB::ifDescr.2 = STRING: ix1 IF-MIB::ifDescr.3 = STRING: bge0 IF-MIB::ifDescr.4 = STRING: bge1 IF-MIB::ifDescr.5 = STRING: lo0 IF-MIB::ifDescr.6 = STRING: pflog0 IF-MIB::ifDescr.7 = STRING: lagg0 IF-MIB::ifDescr.8 = STRING: vlan10 IF-MIB::ifDescr.9 = STRING: vlan40 IF-MIB::ifDescr.10 = STRING: vlan60 IF-MIB::ifDescr.11 = STRING: vlan110 IF-MIB::ifDescr.12 = STRING: vlan120 IF-MIB::ifDescr.13 = STRING: ue0
[root@zabbix mibs]# snmpwalk -v 2c -c public 192.168.40.40 FREENAS-MIB::zfsArcSize FREENAS-MIB::zfsArcSize = No Such Object available on this agent at this OID
