Transmission plugin mount points
Lacika1981
I installed freenas 11.3 on my server.
I have transmission and emby installed as well.
I was able to set up these plugins to reach the content via emby that was downloaded by transmission. Now I am out of luck.
Here is what I have done:
I created mount points. The source directory is where the files are downloaded and the destination is the media folder.
j85m9f
https://ibb.co/iQjtN0
Now when I try to set up a new library in emby and point to a folder then this media folder is empty
mzLpvL
https://ibb.co/mzLpvL
However when I try to check the mount points then I can see this:
iQjtN0
So the content is showing up in the media folder but can not see with emby.
Please help me to solve this problem.
Thanks
Lacika1981
I have got the solution for the problem.
I may did not remember well or something has been changed.
I had to set mount points for the emby jail. The source is the transmission download folder and the destination is the media folder.
It reads the data from there now.
