Matt999
- Apr 21, 2015
Hi everyone,
I'm all Supermicro'd up with my shiny new FreeNAS box which is working as expected, but have a query about my wheezy steam powered FreeNAS test box, as I'm keen to learn all I can about FreeNAS...
When I enter the IP address I get the expected login screen, but when I enter the login details, I get this:-
Request Method: GET
Request URL: http://192.168.1.99/
Software Version: FreeNAS-9.3-CURRENT-201503161938
Exception Type: SystemError
Exception Value:
unknown opcode
Exception Location: /usr/local/www/freenasUI/../freenasUI/support/utils.py in get_license, line 28
Server time: Tue, 2 Jun 2015 17:41:29 +0100
Traceback
Environment: Software Version: FreeNAS-9.3-CURRENT-201503161938 Request Method: GET Request URL: http://192.168.1.99/ Traceback: File "/usr/local/lib/python2.7/site-packages/django/core/handlers/base.py" in get_response 105. response = middleware_method(request, callback, callback_args, callback_kwargs) File "/usr/local/www/freenasUI/../freenasUI/freeadmin/middleware.py" in process_view 157. return login_required(view_func)(request, *view_args, **view_kwargs) File "/usr/local/lib/python2.7/site-packages/django/contrib/auth/decorators.py" in _wrapped_view 22. return view_func(request, *args, **kwargs) File "/usr/local/lib/python2.7/site-packages/django/views/decorators/cache.py" in _wrapped_view_func 52. response = view_func(request, *args, **kwargs) File "/usr/local/www/freenasUI/../freenasUI/freeadmin/site.py" in adminInterface 236. 'menu_hook': appPool.get_top_menu(request), File "/usr/local/www/freenasUI/../freenasUI/freeadmin/apppool.py" in get_top_menu 45. arr = self._get_array("top_menu", None, request) File "/usr/local/www/freenasUI/../freenasUI/freeadmin/apppool.py" in _get_array 35. method(arr, func(*args, **kwargs)) File "/usr/local/www/freenasUI/../freenasUI/plugins/hook.py" in top_menu 13. if jails_enabled(): File "/usr/local/www/freenasUI/../freenasUI/support/utils.py" in jails_enabled 68. license, reason = get_license() File "/usr/local/www/freenasUI/../freenasUI/support/utils.py" in get_license 28. if not os.path.exists(LICENSE_FILE): Exception Type: SystemError at / Exception Value: unknown opcode
Request information
GET
No GET data
POST
No POST data
FILES
No FILES data
COOKIES
Variable Value
sessionid 'h1xnrjf0zgh0st9ojb2yzp2ows6k4bzd'
csrftoken 'IXU51pj4geUQA7p6juTpihMlB0EwKbYL'
META
Variable Value
SERVER_PORT '80'
REMOTE_ADDR '192.168.1.13'
REQUEST_URI '/'
SERVER_NAME 'localhost'
SERVER_SOFTWARE 'nginx/1.6.2'
SERVER_ADDR '192.168.1.99'
HTTP_ACCEPT 'text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8'
DOCUMENT_ROOT '/usr/local/etc/nginx/html'
HTTP_ACCEPT_LANGUAGE 'en-GB,en;q=0.5'
wsgi.url_scheme 'http'
wsgi.multiprocess False
wsgi.errors <flup.server.fcgi_base.TeeOutputStream object at 0x8139d5b50>
REMOTE_PORT '63886'
HTTP_COOKIE 'csrftoken=IXU51pj4geUQA7p6juTpihMlB0EwKbYL; sessionid=h1xnrjf0zgh0st9ojb2yzp2ows6k4bzd'
wsgi.run_once False
DOCUMENT_URI '/'
SERVER_PROTOCOL 'HTTP/1.1'
wsgi.version (1, 0)
REQUEST_METHOD 'GET'
HTTP_HOST '192.168.1.99'
CONTENT_TYPE ''
wsgi.input <flup.server.fcgi_base.InputStream object at 0x8139d5a10>
HTTPS ''
PATH_INFO u'/'
HTTP_ACCEPT_ENCODING 'gzip, deflate'
GATEWAY_INTERFACE 'CGI/1.1'
CONTENT_LENGTH ''
REDIRECT_STATUS '200'
HTTP_CONNECTION 'keep-alive'
wsgi.multithread True
SCRIPT_NAME u''
QUERY_STRING ''
HTTP_USER_AGENT 'Mozilla/5.0 (Windows NT 6.1; WOW64; rv:38.0) Gecko/20100101 Firefox/38.0'
CSRF_COOKIE u'IXU51pj4geUQA7p6juTpihMlB0EwKbYL'
Is this an example of why you should always use ECC RAM? (it's only a test box made from redundant hardware, so just ordinary RAM. My new box has recommended hardware)
There is no critical data on there, should I just press the reset button on my box and cross my fingers, or is there some other way out? I'd like to keep it available if possible, but reinstalling is not a problem
Kind regards,
Matthew
Request Method: GET
Exception Value:
unknown opcode
Traceback
Request information
GET
No GET data
POST
No POST data
FILES
No FILES data
COOKIES
Variable Value
META
Variable Value
SERVER_PORT '80'
REQUEST_URI '/'
REMOTE_PORT '63886'
wsgi.run_once False
DOCUMENT_URI '/'
wsgi.version (1, 0)
CONTENT_TYPE ''
HTTPS ''
PATH_INFO u'/'
CONTENT_LENGTH ''
SCRIPT_NAME u''
QUERY_STRING ''
Kind regards,
Matthew
