To long serial usb device
How can i fix this long serial at this moment i can't disable the smart on my usb so it won't start seen image
error text if i want to disable smart
Ensure this value has at most 30 characters (it has 120).
who can help me
Thanks
D
dlavigne
Guest
I ran into problems using drives that had normal length serial numbers, but the value was all zero. Is that something you could look into?
It's worth creating a ticket that includes a debug as the fix for weird values is often hardware-specific. If you do, post the issue number please.
stil got the same long serial Version: FreeNAS-11.3-RC1
