ninthturtle1034
- Jan 7, 2023
Hi I seem to be having issues setting up ACL permissions on my NFS & SMB share on my TrueNAS Scale system. I keep getting these kinds of errors when I don't have a `mask` or `other` entry in the share
but when I add a `mask` or `other` entry the error persists.
If it's at all useful my usecase is that I setup a NFS share to store my proxmox VM disks on but then due to some networking issues the proxmox host stopped being able to connect to the share so can't load the VM. I have manged to connect via SMB and retrieve the VM but I'd like to be able to reconnect my proxmox host to the share but it keeps having permission issues which I'm having issues troubleshooting.
[EINVAL] filesystem_acl.dacl: Named (user or group) POSIX ACL entries require a mask entry to be present in the ACL. [EINVAL] filesystem_acl.dacl: Default ACL entries are required in order to apply ACL recursively. [EINVAL] filesystem_acl.dacl: Presence of [OTHER] entry is required. More info...
Error: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/job.py", line 426, in run await self.future File "/usr/lib/python3/dist-packages/middlewared/job.py", line 463, in __run_body rv = await self.middleware.run_in_thread(self.method, *([self] + args)) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1172, in run_in_thread return await self.run_in_executor(self.thread_pool_executor, method, *args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1169, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) File "/usr/lib/python3.9/concurrent/futures/thread.py", line 52, in run result = self.fn(*self.args, **self.kwargs) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1288, in nf return func(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/filesystem_/acl_linux.py", line 678, in setacl return self.setacl_posix1e(job, data) File "/usr/lib/python3/dist-packages/middlewared/plugins/filesystem_/acl_linux.py", line 637, in setacl_posix1e verrors.check() File "/usr/lib/python3/dist-packages/middlewared/service_exception.py", line 70, in check raise self middlewared.service_exception.ValidationErrors: [EINVAL] filesystem_acl.dacl: Named (user or group) POSIX ACL entries require a mask entry to be present in the ACL. [EINVAL] filesystem_acl.dacl: Default ACL entries are required in order to apply ACL recursively. [EINVAL] filesystem_acl.dacl: Presence of [OTHER] entry is required.
