jakesmorrison
- Feb 8, 2023
I have been using TrueNAS Scale Bluefin for a few months and it has been working great. I shutdown my machine this afternoon to upgrade the memory. Booted it back up and I am stuck with a strange error.
My installed applications are not showing and there is an error that states, "Applications are not running". I try to, "Unset Pool", but I get the following error:
I checked the status of k3s and it is running:
Any suggestions?
Thanks
Code: CRITICAL Failed to start kubernetes cluster for Applications: Received 500 response code from '/api/v1/secrets?fieldSelector=type%3Dhelm.sh%2Frelease.v1' |
Code: FAILED
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 426, in run
await self.future
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 461, in __run_body
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1152, in nf
res = await f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1284, in nf
File "/usr/lib/python3/dist-packages/middlewared/plugins/kubernetes_linux/update.py", line 437, in do_update
await self.middleware.call('chart.release.clear_update_alerts_for_all_chart_releases')
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1306, in call
return await self._call(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1255, in _call
File "/usr/lib/python3/dist-packages/middlewared/plugins/chart_releases_linux/upgrade.py", line 449, in clear_update_alerts_for_all_chart_releases
for chart_release in await self.middleware.call('chart.release.query'):
File "/usr/lib/python3/dist-packages/middlewared/plugins/chart_releases_linux/chart_release.py", line 180, in query
release_secrets = await self.middleware.call('chart.release.releases_secrets', extra)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1266, in _call
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1169, in run_in_executor
File "/usr/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/usr/lib/python3/dist-packages/middlewared/plugins/chart_releases_linux/secrets_management.py", line 36, in releases_secrets
secrets = self.middleware.call_sync(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1325, in call_sync
return self.run_coroutine(methodobj(*prepared_call.args))
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1365, in run_coroutine
return fut.result()
File "/usr/lib/python3.9/concurrent/futures/_base.py", line 433, in result
return self.__get_result()
File "/usr/lib/python3.9/concurrent/futures/_base.py", line 389, in __get_result
raise self._exception
File "/usr/lib/python3/dist-packages/middlewared/plugins/kubernetes_linux/k8s_base_resources.py", line 30, in query
d for d in (await self.KUBERNETES_RESOURCE.query(**kwargs))['items']
File "/usr/lib/python3/dist-packages/middlewared/plugins/kubernetes_linux/k8s/client.py", line 99, in query
return await cls.call(
File "/usr/lib/python3/dist-packages/middlewared/plugins/kubernetes_linux/k8s/client.py", line 84, in call
return await cls.api_call(uri, mode, body, headers, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/kubernetes_linux/k8s/client.py", line 45, in api_call
async with cls.request(endpoint, mode, body, headers, timeout) as resp:
File "/usr/lib/python3.9/contextlib.py", line 175, in __aenter__
return await self.gen.__anext__()
File "/usr/lib/python3/dist-packages/middlewared/plugins/kubernetes_linux/k8s/client.py", line 33, in request
raise ApiException(f'Received {resp.status!r} response code from {endpoint!r}')
middlewared.plugins.kubernetes_linux.k8s.exceptions.ApiException: Received 500 response code from '/api/v1/secrets?fieldSelector=type%3Dhelm.sh%2Frelease.v1' |
Code: root@truenas[~]# systemctl status k3s
● k3s.service - Lightweight Kubernetes
Loaded: loaded (/lib/systemd/system/k3s.service; disabled; vendor preset: disabled)
Active: active (running) since Wed 2023-02-08 18:29:00 MST; 19min ago
Docs: https://k3s.io
Process: 201578 ExecStartPre=/sbin/modprobe br_netfilter (code=exited, status=0/SUCCESS)
Process: 201579 ExecStartPre=/sbin/modprobe overlay (code=exited, status=0/SUCCESS)
Main PID: 201582 (k3s-server)
Tasks: 48
Memory: 887.9M
CPU: 4min 6.159s
CGroup: /system.slice/k3s.service
└─201582 /usr/local/bin/k3s server
Feb 08 18:47:51 truenas k3s[201582]: E0208 18:47:51.989647 201582 nestedpendingoperations.go:348] Operation for "{volumeName:kubernetes.io/csi/zfs.csi.openebs.io^pvc-f1fb05d1-b4f1-4442-8785-198eb1e7ea88 podName:d9d80676-a4b1>
Feb 08 18:47:51 truenas k3s[201582]: E0208 18:47:51.990477 201582 nestedpendingoperations.go:348] Operation for "{volumeName:kubernetes.io/csi/zfs.csi.openebs.io^pvc-ac43cf67-5b30-41aa-8f80-127980da6768 podName:619443c5-9093>
Feb 08 18:47:51 truenas k3s[201582]: E0208 18:47:51.990644 201582 nestedpendingoperations.go:348] Operation for "{volumeName:kubernetes.io/csi/zfs.csi.openebs.io^pvc-31caee9e-2d95-4231-87d4-0694d43cd68a podName:b4053797-22a2>
Feb 08 18:47:51 truenas k3s[201582]: E0208 18:47:51.991051 201582 nestedpendingoperations.go:348] Operation for "{volumeName:kubernetes.io/csi/zfs.csi.openebs.io^pvc-4101eccf-bb14-49b1-96f8-ea6cff109d73 podName:b0905c29-ab0b>
Feb 08 18:47:51 truenas k3s[201582]: E0208 18:47:51.991848 201582 nestedpendingoperations.go:348] Operation for "{volumeName:kubernetes.io/csi/zfs.csi.openebs.io^pvc-f7b6b4b6-af51-4c9a-9249-34325002397e podName:0ab402a4-08df>
Feb 08 18:47:51 truenas k3s[201582]: E0208 18:47:51.993661 201582 nestedpendingoperations.go:348] Operation for "{volumeName:kubernetes.io/csi/zfs.csi.openebs.io^pvc-83b3a9ef-fea7-47d4-a379-91e2ce04eedc podName:d9d80676-a4b1>
Feb 08 18:47:51 truenas k3s[201582]: E0208 18:47:51.993725 201582 nestedpendingoperations.go:348] Operation for "{volumeName:kubernetes.io/csi/zfs.csi.openebs.io^pvc-b0805f1c-5684-4460-8b34-4316a42231fa podName:f57e7d56-5dcd>
Feb 08 18:47:51 truenas k3s[201582]: E0208 18:47:51.994449 201582 nestedpendingoperations.go:348] Operation for "{volumeName:kubernetes.io/csi/zfs.csi.openebs.io^pvc-8da163d1-2436-4489-a402-3a11d0ff427e podName:0ab402a4-08df>
Feb 08 18:47:55 truenas k3s[201582]: time="2023-02-08T18:47:55-07:00" level=info msg="Using CNI configuration file /etc/cni/net.d/00-multus.conf"
Feb 08 18:48:00 truenas k3s[201582]: time="2023-02-08T18:48:00-07:00" level=info msg="Using CNI configuration file /etc/cni/net.d/00-multus.conf" |
Any suggestions?
Thanks
