bakhanbeigi
- Dec 21, 2022
Recently, I accidentally deleted some files from one of my datasets. I have a replication on local media, but I realized the files are not available there.
The replication task was applied to the parent dataset, and I had forgotten to check the "recursive" and "full filesystem replications" options.
Now when I check the replication destination, I only see a directory of sub-datasets, each of which looks empty, but the size of the partition shows it is not empty.
Removing the read-only flag from the main dataset did not help access the files. Is there anyway to access the files or it is because of missing checkboxes of the replication task?
I also have a daily cloud sync on AWS S3 Glacier, but it is encrypted, and I am not sure if it is possible to restore only one directory.
Is there any way to restore deleted files?
root@cloud[~]# zfs set readonly=off external_backup/cloud
root@cloud[~]# ls /mnt/external_backup/cloud/private -la
total 17
d---r-x---+ 2 root root 2 Feb 11 02:15 .
drwxrwx---+ 5 root root 7 Mar 31 20:48 ..
root@cloud[~]# ls /mnt/external_backup/cloud -la
total 32
drwxr-xr-x 5 root root 6 Jul 31 04:00 ..
----rwx--- 1 root root 542 Dec 18 2022 .htaccess
----rwx--- 1 root root 0 Dec 18 2022 .ocdata
d---r-x---+ 2 root root 2 Feb 11 02:15 private
d---r-x---+ 2 root root 2 Feb 11 02:16 public
root@cloud[~]# zfs get readonly external_backup/cloud/private
cannot open 'external_backup/cloud/private': dataset does not exist
