nissnn
- Mar 14, 2019
Hello Everybody,
Today I was cleaning my NAS Build and when powering it back on afterwards one drive was not showing up and this error was showing:
I shut down the system and checked all the cabling, when powering on again the drive showed up but I still get the same error.
Running zpool Status returns this:
The drive that was not showing up and is now unavailable seems to be fine:
Onlining it doesn't work I just get:
Is it possible that the drive is just not properly recognised because it was missing once and can I somehow reconnect it?
Thanks for reading,
nissnn
The volume Speicherplatz state is DEGRADED: One or more devices could not be opened. Sufficient replicas exist for the pool to continue functioning in a degraded state.
pool: Speicherplatz
state: DEGRADED
status: One or more devices could not be opened. Sufficient replicas exist for
action: Attach the missing device and online it using 'zpool online'.
see: http://illumos.org/msg/ZFS-8000-2Q
scan: none requested
NAME STATE READ WRITE CKSUM
Speicherplatz DEGRADED 0 0 0
raidz1-0 DEGRADED 0 0 0
gptid/d3490947-4009-11e9-b436-bcaec5dcfcad.eli ONLINE 0 0 0
15070291121131822168 UNAVAIL 0 0 0 was /dev/gptid/d46c4f36-4009-11e9-b436-bcaec5dcfcad.eli
gptid/d5b48372-4009-11e9-b436-bcaec5dcfcad.eli ONLINE 0 0 0
gptid/d6f078d8-4009-11e9-b436-bcaec5dcfcad.eli ONLINE 0 0 0
errors: No known data errors
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0 days 00:00:03 with 0 errors on Thu Mar 14 03:45:03 2019
freenas-boot ONLINE 0 0 0
ada3p2 ONLINE 0 0 0
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Seagate Enterprise Capacity 3.5 HDD
Device Model: ST10000NM0086-2AA101
Serial Number: ZA21ET7T
LU WWN Device Id: 5 000c50 074424642
Firmware Version: SN05
User Capacity: 10,000,831,348,736 bytes [10.0 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Wed Mar 20 20:42:40 2019 CET
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 567) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 950) minutes.
Conveyance self-test routine
SCT capabilities: (0x70bd) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000f 080 064 044 Pre-fail Always - 108588180
3 Spin_Up_Time 0x0003 091 091 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 37
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 082 060 045 Pre-fail Always - 171839681
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 687
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 37
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0 0 0
189 High_Fly_Writes 0x003a 064 064 000 Old_age Always - 36
190 Airflow_Temperature_Cel 0x0022 065 053 040 Old_age Always - 35 (Min/Max 34/35)
191 G-Sense_Error_Rate 0x0032 098 098 000 Old_age Always - 5539
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 30
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 142
194 Temperature_Celsius 0x0022 035 047 000 Old_age Always - 35 (0 19 0 0 0)
195 Hardware_ECC_Recovered 0x001a 080 064 000 Old_age Always - 108588180
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0023 100 100 001 Pre-fail Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 683h+37m+44.452s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 110853972576
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 138308350991
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Completed without error 00% 684 -
# 2 Extended offline Interrupted (host reset) 00% 655 -
# 3 Extended offline Completed without error 00% 636 -
# 4 Extended offline Aborted by host 20% 609 -
# 5 Extended offline Completed without error 00% 589 -
# 6 Extended offline Completed without error 00% 560 -
# 7 Extended offline Interrupted (host reset) 60% 493 -
# 8 Extended offline Interrupted (host reset) 80% 466 -
# 9 Extended offline Interrupted (host reset) 90% 441 -
#10 Extended offline Interrupted (host reset) 80% 422 -
#11 Extended offline Completed without error 00% 16 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
warning: device '15070291121131822168' onlined, but remains in faulted state
Thanks for reading,
nissnn
