The Supermicro ipmi KCS-error (and Usb Problem?) keeps popping up at recurrin intervalls...what now?
Ceetan
The Supermicro ipmi KCS-error (and Usb Problem?) keeps popping up at recurrin intervalls. I posted about it a while back, and i guess Iam still unsure of what to do: Is a bios in order ?
Pastebin link to output
https://pastebin.com/LQtmmppj
Chris Moore
Can you be a whole lot more specific about exactly what it is that you're having problem with? That list that you pointed at is a mile and a half long and I don't think anybody's going to read through all that.
Ceetan
I'll try, wth the caveat that I dont compleltly under stand what is going on, so selecting revlevant data might be tricky. The being said, I think i have snippet onne segment of the repeated data. Maybe one and a half, but i did my best.
I was thinking it may be related to this Put Iam also worried something me be worng with the USB connected to the UPS.
Darwin.local kernel log messages:
> ipmi0: KCS: Failed to start write
> ipmi0: KCS error: ff
> ugen0.3: <vendor 0x0557 product 0x7000> at usbus0 (disconnected)
> ipmi0: uhub1: at uhub0, port 12, addr 53 (disconnected)
> KCS: Reply address mismatch
> ugen0.4: <vendor 0x0557 product 0x2419> at usbus0 (disconnected)
> ukbd0: at uhub1, port 1, addr 52 (disconnected)
> ukbd0: detached
> ums0: at uhub1, port 1, addr 52 (disconnected)
> ums0: detached
> uhub1: detached
> ipmi0: KCS Error Data ff
> usbd_setup_device_desc: getting device descriptor at addr 56 failed, USB_ERR_SHORT_XFER
> uhub1 on uhub0
> uhub1: <vendor 0x0557 product 0x7000, class 9/0, rev 2.00/0.00, addr 56> on usbus0
> uhub1: 4 ports with 3 removable, self powered
> ukbd0 on uhub1
> ukbd0: <vendor 0x0557 product 0x2419, class 0/0, rev 1.10/1.00, addr 57> on usbus0
> kbd0 at ukbd0
> ums0 on uhub1
> ums0: <vendor 0x0557 product 0x2419, class 0/0, rev 1.10/1.00, addr 57> on usbus0
> ums0: 3 buttons and [XYZ] coordinates ID=0
> ipmi0: KCS: Error retry exhausted
> ukbd0: at uhub1, port 1, addr 57 (disconnected)
> ukbd0: detached
> ums0: at uhub1, port 1, addr 57 (disconnected)
> ums0: detached
> ukbd0 on uhub1
> ukbd0: <vendor 0x0557 product 0x2419, class 0/0, rev 1.10/1.00, addr 55> on usbus0
> kbd0 at ukbd0
> ums0 on uhub1
> ums0: <vendor 0x0557 product 0x2419, class 0/0, rev 1.10/1.00, addr 55> on usbus0
> ums0: 3 buttons and [Z] coordinates ID=0
> uhub1: at uhub0, port 12, addr 56 (disconnected)
> ukbd0: at uhub1, port 1, addr 55 (disconnected)
> ukbd0: detached
> ums0: at uhub1, port 1, addr 55 (disconnected)
> ums0: detached
> uhub1: detached
> usbd_setup_device_desc: getting device descriptor at addr 59 failed, USB_ERR_SHORT_XFER
> uhub1 on uhub0
> uhub1: <vendor 0x0557 product 0x7000, class 9/0, rev 2.00/0.00, addr 59> on usbus0
> ukbd0 on uhub1
> ukbd0: <vendor 0x0557 product 0x2419, class 0/0, rev 1.10/1.00, addr 60> on usbus0
> kbd0 at ukbd0
> ums0 on uhub1
> ums0: <vendor 0x0557 product 0x2419, class 0/0, rev 1.10/1.00, addr 60> on usbus0
> ukbd0: at uhub1, port 1, addr 60 (disconnected)
> ukbd0: detached
> ums0: at uhub1, port 1, addr 60 (disconnected)
> ums0: detached
> ukbd0 on uhub1
> ukbd0: <vendor 0x0557 product 0x2419, class 0/0, rev 1.10/1.00, addr 58> on usbus0
> kbd0 at ukbd0
> ums0 on uhub1
> ums0: <vendor 0x0557 product 0x2419, class 0/0, rev 1.10/1.00, addr 58> on usbus0
> uhub1: at uhub0, port 12, addr 59 (disconnected)
> ukbd0: at uhub1, port 1, addr 58 (disconnected)
> ukbd0: detached
> ums0: at uhub1, port 1, addr 58 (disconnected)
> ums0: detached
> uhub1: detached
