The NAS system crashed, how to copy the configuration file
derock
I can't read the system files in the U disk using the winallfs software, use the 9.10.2 version, or how to mount it on the new NAS system.
You will have to explain what your problem is, exactly, in coherent sentences, because your question does not parse.
winallfs software
Whatever you're trying to do with that, whatever it claims to do, don't. It will not work.
derock
I reinstalled FreeNAS, there are three volumes, but I only see two after importing.
gpsguy
Active Member
Please provide detailed system information.
Also,post the results of zpool status
derock
FreeNAS-9.10.2-U6 (561f0d7a1)
[root@freenas] ~# zpool status
  pool: freenas-boot
state: ONLINE
  scan: none requested
        freenas-boot  ONLINE       0     0     0
          da4p2     ONLINE       0     0     0
errors: No known data errors
  pool: oldboot
state: ONLINE
  scan: scrub repaired 0 in 1h18m with 0 errors on Sun Nov 25 01:19:05 2018
        oldboot                                         ONLINE       0     0     0
          raidz1-0                                      ONLINE       0     0     0
            gptid/8d48b649-822c-11e7-bc61-a0369f039cd4  ONLINE       0     0     0
            gptid/8e14b7e2-822c-11e7-bc61-a0369f039cd4  ONLINE       0     0     0
            gptid/8ed20e83-822c-11e7-bc61-a0369f039cd4  ONLINE       0     0     0
            gptid/8ff06e97-822c-11e7-bc61-a0369f039cd4  ONLINE       0     0     0
  pool: oldboot1
state: ONLINE
  scan: scrub repaired 28K in 11h51m with 0 errors on Sun Nov 25 11:51:20 2018
        oldboot1                                        ONLINE       0     0     0
          raidz2-0                                      ONLINE       0     0     0
            gptid/4b8ecec7-43d4-11e7-883e-a0369f039cd4  ONLINE       0     0     0
            gptid/4c5c624e-43d4-11e7-883e-a0369f039cd4  ONLINE       0     0     0
            gptid/4d37886a-43d4-11e7-883e-a0369f039cd4  ONLINE       0     0     0
            gptid/4e18d220-43d4-11e7-883e-a0369f039cd4  ONLINE       0     0     0
Thank you !
You have one RAIDZ2 pool and one RAIDZ1 pool, besides your current boot pool. Despite being called "oldboot", they are definitely not boot pools, because only mirrors are supported.
derock
There are two disks. I am now trying to import the disk into the volume. Will the disk data be lost?
That does not make any sense. Definitely do not do whatever it is you're suggesting, at least until somebody else figures out what you're trying to do.
gpsguy
Active Member
Earlier, I asked for detailed system information. Giving us just the FreeNAS version isn't detailed enough.
We're looking for things like, motherboard, CPU, RAM, Hard disks - quantity, type, capacity, etc. How are they connected: HBA, directly to the montherboard, or ???
Based on what you've showed us, we see that you have 8 drives in your two data pools and one drive (not sure of the type) in your boot pool.
Like @Ericloewe, I don't understand your comment about the "2 disks". Do you have 10 hard disks in your server?
derock
Yes, there are 10 hard drives, the data is in the other two hard drives, I am importing.
Connected:ISCSI
Import disk imports non-ZFS storage into a ZFS dataset. Is this what you want?
Then what's the problem? Wait for it to finish.
...and what on earth does that have to do with the thread title?
@derock, you're dribbling out bits and pieces of information that make no sense, don't connect to each other, don't answer the questions asked of you, and don't seem to have anything to do with the stated subject of this thread. Why don't you take it from the top, and explain, in detail:
  • Exactly what happened with your system
  • Exactly what you're trying to accomplish
  • Exactly what you're doing in order to try to accomplish that
  • Exactly what happens when you do it
  • Exactly how "what happens" differs from what you expected would happen
Feel free (indeed, encouraged) to use multiple sentences, or even paragraphs, to discuss these subjects. Keep in mind that none of us are mind-readers.
