The most compatible UPS for FreeNAS
Radu
I am interested in a UPS that works fine with FreeNAS from the alerts point of view and connectivity. Any opinion from a tested solution?
Radu
I can not find it in my country unfortunately, this model :(
TheSmoker
Best way is to check in the list of the upses provided by nut in the freenas interface.
Ablerex usb is supported as well. :P as well as some mustek and socomec. The secret is to read nut's compatibility list and map it to what currently you have available in your country.
Radu
Alberex VT PRO 1500 it's not supported. The best i can think of is EATON Ellipse ECO 800VA USB. It's fully supported and available in my country ... kind of expensive ...
TheSmoker
Have you tried? What is the output of upsc ups after you properly configured the port?
What driver have you selected?
Radu
I have tried and failed until now. Driver blazer_usb. Port /dev/ugen0.5.
TheSmoker
Let me check again how i made it work on freebsd and i will get back to you. Momentarily i am out of the country...
