I've been using FreeNAS-8.0.2-RELEASE-amd64 (8288) for many months now with two disks in a mirrored configuration.
Or at least I thought I had a mirrored configuration.
Today I finally got around to testing the rebuild capability of the mirror.
I pulled out the second of the 2 disks (let's call it the disk that was in the second disk slot), replaced it with a new disk of the same make/model/size, brought the system back up and tried to get to the data.
When the system came back up, I logged into the GUI and saw this for the volume:
That was the only volume listed. I've only ever had one volume listed though.
At first this lead me to believe that all the data was only on the disk I pulled out (from the second slot) and there was not a copy on the disk in the first slot.
For another check, I moved the new disk from the second slot to the first slot, moved the disk that was originally in the first slot into the second slot, and still kept out the disk that I originally pulled from the second slot.
Now when the system comes back up, the GUI reports this for the volume:
That's more like what I expected to see.
However, when I mount the volume, it appears to be empty. But before the test I had data on all but about 3 GiB of the 1.5 (1.3) TiB volume.
So should my data already be available?
Or do I need to wait for the system to re-make the mirror (assuming it is doing that)?
[edit] This system is one of those Intel SS4200 home file servers, if that makes a difference. Actually, it is the Siemens SCALEO version with an upgraded CPU and RAM (2 GB). Booting from USB stick.
Thanks in advance for your help!
Volume Path Used Available Size Status vol1 /mnt/vol1 None (Error) Error getting available space Error getting total space <forgot to capture this field>
Volume Path Used Available Size Status vol1 /mnt/vol1 21.0 KiB (0%) 1.3 TiB 1.3 TiB DEGRADED
